My first time, Aleph 30 DONE!
Old 2nd October 2006, 02:10 PM   #1
Peppe is offline Peppe  Italy
Cool My first time, Aleph 30 DONE!
Hi at all,
this Aleph30clone is my first DIY-project! So, like first think I would to tanks all the people on diyaudio forum because on their technical exchange I learned all about my work. Tanks especially to Mr Pass who allowed me to live the “Frankenstein experience” when I gave life for my first time my Aleph and it sang for me!
The PCBs are from BrianGT and the parts are exactly from his list. The toroidal is 650VA 2x22Volt, the R in the CCRC arrangement is a parallel of 5x3 Ohm 3 Watt (0,6R total) per rail. A 3,3 µF MKT is used like capacitor filter and under load the PSU deliver +/- 24,7 Volt. Total bias is 2,1A for each channel and the DC offset is -15 and -20 mV.
The IRFP240 (not from digikey) are in TO-220 case and mounted with mica insulator and thermal silicon paste on the heatsink (300x160x40 mm). After 3 hours while Tamb is 20°C the Tcase is 58°C, a little high to touch for more than 3 seconds the heatsinks!
After mounted the front panel (aluminium 1 cm thin), the Tcase decries to 55 °C (?!), Tamb still 20°C. So (55-20)°C/(24,7Vx2)x2,1A -> 35°C/104Watt -> Rth=0,33 C/W about. Is it correct?
Measuring the T on the metal side of the mosfets it rises to 80°C in the worse case,
I must be in hurry? I won’t to use a fun…
No noise in the speaker, very little hum from the toroidal and no bump when turn the switch on or off.
The sound is really 3D with great separation, the instruments are present and detailed.
Tanks again!
Peppe
Old 2nd October 2006, 02:14 PM   #2
heatsinks mounted to not burn the table
Old 2nd October 2006, 02:16 PM   #3
with the front panel
Old 2nd October 2006, 02:17 PM   #4
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Peppe,
who made the case ?
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 2nd October 2006, 02:17 PM   #5
the rear
Old 2nd October 2006, 02:21 PM   #6
Originally posted by jacco vermeulen
Peppe,
who made the case ?
Hi Jacco,
the case is from http://www.hifi2000.it/ and I bought the 1NPD04300 B on www.audiokit.it.
Old 2nd October 2006, 02:57 PM   #7
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Peppe,
That is, quite simply, beautiful work. I like the cases offered from hifi2000, too.
Steve
Old 2nd October 2006, 03:08 PM   #8
Originally posted by N-Channel
Peppe,
Steve
Tanks Steve
the case have a beautiful 10mm thin panel, but I'm not able to work on it to put a switch. The led (deep red) is in the switch on the rear.
Old 4th October 2006, 09:47 AM   #9
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Originally posted by Peppe
Tanks Steve
Hi Peppe,
why not? It is because of the 10 mm depth?
If so you can use a trick, drill a blind hole from the back with a large diameter and you can fit a switch in such a monster panel.
Cheers
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 4th October 2006, 10:20 AM   #10
Yes Andrea,
it's not easy to work on 10 mm depth panel for me. Yours it's a very good idea, my switch need 19 mm diameter hole so I need a drill tip of 23-25 mm about. Such tip is very expensive.
Another way (more expensive) could be to order to HiFi2000 a drilled front panel with personal serigraphy.
I will try to email Hifi2000 or follow your trick.
Tanks
My first time, Aleph 30 DONE!Hide this!Advertise here!
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 01:55 PM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 09:10 PM
Aleph Heat Up Time? TwangBar Pass Labs 28 23rd October 2004 05:52 AM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 06:45 AM
Aleph 5 (Mosfet matching time) billy Pass Labs 3 18th January 2003 03:32 PM
Copyright ©1999-2017 diyAudio
