Old 16th December 2002, 08:37 PM   #1
Default Upping the bias on Aleph 2
What is the proper way to up the bias on the Aleph 2? Should I replace the 56K resistor with a pot, or just say take half the value....27K and then make up the difference with a pot? Does this resistance have to go up or down to increase the bias?
My amp is running right at 3 amps idle but with all the heatsinking I have I could go higher and would like to try this.
Thanks in advance for any input on this.....
Mark
Old 16th December 2002, 09:26 PM   #2
Freddie is offline Freddie  Sweden
If you increase the resistance the bias goes up. So I just put a 100k pot in series with the resistor (on my Aleph 30).
/Freddie
Old 16th December 2002, 10:45 PM   #3
diyAudio Moderator Emeritus
roddyama's Avatar
Hi Mark,
Here are two threads that dealt with the bias setting. The first is for fcel's Aleph 2 and the second starts with the Aleph 5 and shows how close all the Aleph’s are as it William (wuffwaff) talks about adding output devices and turning a A5 into a A2. There is also some input from Mr. Pass.
DC offset / Bias setting for Aleph 2
Aleph5....it works!!!
Rodd Yamashita
Old 17th December 2002, 12:16 AM   #4
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Get the 200k trimpot, adjust it to 56K and put in your circuit. Then increase the value untill you get required bias, remove trimpot, measure and replace with fixed resistor.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 17th December 2002, 07:27 PM   #5
Yes, that would be a good way to do it. No need to try
calculating everything.
BTW, I'm thinking that for the Aleph-X, I may try to have
two bias settings controlled by a switch. Kinda a summer/
winter setting switch.
Old 17th December 2002, 08:00 PM   #6
wuffwaff's Avatar
don´t forget the second switch for the ac-current -gain setting.
That will be 8 switches for a stereo amp then
william
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 17th December 2002, 10:45 PM   #7
william
Hmmm...good point. Maybe I should just build
summer and winter amps.
Dennis
Old 17th December 2002, 11:04 PM   #8
Why not choosing Spring or Fall settings on the amp?
www.audiosector.com
Old 18th December 2002, 01:42 AM   #9
I did the 200K trimpot install as Peter suggested and that is definately the way to do things. Will install the fixed resistor tommrrow. A bit more temperature rise but after two hours of operation I can still keep my hands on top of the sinks and its not uncomfortable at all. I think these heat sinks work really well!! I can forget the need for a Winter/Summer bias setting for sure.
I wonder what would have caused the bias to be a tenth of a volt low? anyone got any ideas.... I did use IRFP240's instead of the 244's in my amp. Could this be why?
Mark
Old 18th December 2002, 02:47 AM   #10
Another note: I raised the heatsinks up off the table(da). This has lowered the device case temp by almost 10 degrees to 57 deg.C after about a half hour or so of being elevated 3". Gee, now air is flowing through the sinks! I think I can lower the case temp even lower if I can find any mica insulators in TO-247 size. Am only using cheapo NTE pads for now till I find some.
Mark
Upping voltage on a toroid carlmart Solid State 7 1st September 2007 10:56 AM
Aleph 5 bias billy Pass Labs 8 11th April 2003 01:35 PM
bias set for aleph marijan Pass Labs 3 24th July 2002 05:46 AM
aleph bias, ... janey Pass Labs 3 10th June 2002 12:40 PM
Aleph 60 bias problem explorer Pass Labs 9 1st April 2002 06:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
