Pearl need help
Pearl need help
Old 26th September 2006, 02:26 PM   #1
dzkh63 is offline dzkh63  Hong Kong
Default Pearl need help
I clone a Pearl phono stage a year ago( PC board order from Pass-Labs), all check point voltage was correct and good performance. since I stop use it 6 months, today it is out of working-right chanel no sound and left chanel have very small sound. I open the cover and measure the check points voltage. the Q5 - Q8,Q9,Q10,Q11 point voltage before is 10.75V now only 1.80V (both chanel same), R18 - R21 point before 11.52V now 2.23V, R23 point was 15.11V now 2.45V. Looks like R19 has a lot voltage drop. I have changed Q5 than changed Q8,Q9,Q10,and Q11 but have same result. I don't know how to check the 2SK170's quality, I need help please give your advice.Thank you!
BTW other check points voltage are correct.
Old 26th September 2006, 03:16 PM   #2
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Pearl need help Pearl need help
Default Gnd?
Check ground-path, from psu-in, and on(under) all caps...
Arne K
Don't believe everything you think...
Pearl need helpHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
The Pearl-X Vince Maida Pass Labs 12 28th July 2002 07:28 AM
Copyright ©1999-2017 diyAudio
