Old 17th December 2002, 05:00 AM   #11
A close up of one of the heatsinks showing two of the mosfets and wired with those neato turrett terminals. Thanks to Brian GT for his effort on the PCB's!!
Mark
Old 17th December 2002, 05:04 AM   #12
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Mark
Looks like quite the monster monoblock. I like the turrett terminals. I will have to look for some. Where did you get yours?
The pcbs look so small next to the huge heatsinks.. hard to imagine that they are 4"x6"...
How warm do the heatsinks run after they have been on for a few hours?
Brian
Old 17th December 2002, 05:38 AM   #13
Hi Brian....
Yea...this has been an ongoing project that I was going to do in a months time off from work. So much for that month. It took longer than that just to get the sinks. Then work got really busy too. Oh well........
Look like the temp is around 60 deg. C right now measured on the device itself with my Tektornix temp probe. Its been on for about 4 hours. These sinks work great! Voltage across the one ohm resistors is about a tenth of a volt low right now though so I am expecting a bit higher temperature when I get it cranked up a to .5. I Am going to raise it to .5 volts as per the drawing and leave it there for a while and do some listening. I'll go higher from there after a few days. Right now it sounds really amazing. I've dug out every old mono Jazz CD I could find and listened all night last night. Good mono isn't so bad either. Am driving the amp with my home brew Aleph L.
Mark
Old 17th December 2002, 05:43 AM   #14
The one and only
Nelson Pass's Avatar
Default Re: Aleph 2 Working!!
Perhaps an inductor between caps would clean up things a bit more.
It would indeed. Great job.
Old 17th December 2002, 02:56 PM   #15
Hi Nelson,
Thanks for the kind compliment!! Comming from the Master that really means something. I think I'll print that out and frame to hang on the wall above the Alephs. This has been a most interesting project with more time being spent on making the chassis parts than the electronics itself. Also learning how to match the devices was quite interesting as in all my years of building stuff I had never done that before. My next project will most likely be a balanced preamp to go along with the Alephs.
Kindest regards,
Mark
Aleph ONO working - belated thanks to pquadrat GaryB Pass Labs 96 14th October 2009 07:44 PM
Aleph mini one channel not working yoke Pass Labs 7 9th March 2008 12:15 PM
One Aleph-X working, One to go wuffwaff Pass Labs 102 5th August 2005 07:36 AM
My Aleph-p isn't working PatPet Pass Labs 11 24th August 2004 12:04 PM
My Aleph 5 isn't working DJG Pass Labs 26 7th December 2002 11:49 PM
Page generated in 0.08821 seconds (71.55% PHP - 28.45% MySQL) with 11 queries
