Old 20th September 2006, 02:34 AM   #1
RAM is offline RAM  Indonesia
Default Choke Loaded ZenV8
Hi
I like to make choke loaded ZenV8
I have have make a choke from locally available 1.3mm magnet wire and 9 cm inner diameter, 9 cm wide plastic bobin with 1000 turns
I have measure it weight 4 kg each
and 150 to 170 mH depending on frequency, RDC measure with standard multimeter is 5 Ohms
I need advice from Zen Masters around here.
Beside Voltage supply, anything else should be take care ?
Cheers
RAM
Old 20th September 2006, 04:50 PM   #2
Magura is offline Magura  Denmark
Magura's Avatar
Watch out for the max dissipation of the inductor, 1.3mm magnet wire is not a lot for such an amp.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 30th September 2006, 02:01 AM   #3
Thank you for your advice
any other subject to take car
I need more advice from Zen Masters
and more time to try it on real thing
richard
Choke loaded LTP jane Tubes / Valves 6 8th November 2008 02:25 PM
Hum on a choke loaded stage Sandor Tubes / Valves 0 28th April 2007 09:16 PM
Choke Loaded Zen hacknet Pass Labs 17 8th April 2004 05:45 PM
X-SOZ-X-BOSOZ.....choke loaded Magura Pass Labs 23 27th February 2004 04:38 PM
Is this a choke loaded Xsoz? Fuling Pass Labs 10 31st January 2004 12:20 PM
Page generated in 0.07280 seconds (67.35% PHP - 32.65% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
