Need help with discrete op amps.
Old 17th September 2006, 08:26 PM   #1
cadaverdog is offline cadaverdog  United States
Default Need help with discrete op amps.
I really want to build a set of these for my Rotel RCD-990- especially since I saw all of the circuitry the AD-817 has in it. A few questions:
1. Will the discrete devices have enough drive?
2. If I go with all jfets, which are best.
3. What's with all the extra circuitry in most of these chips?
Thanks for your replies in advance
Old 17th September 2006, 08:37 PM   #2
poobah is offline poobah  United States
poobah's Avatar
What do you want to build?
1) drive what?
2) depends...
3) Assuming you are tlking about the schem for the 817... most of them are current sources and mirrors, pseudo-resistors & capacitors made from transistors.
Old 17th September 2006, 09:05 PM   #3
Default Well.............
Preferably the output will produce the standard +-2Volts and be able to drive a somewhat low input impedance such as a tube amp. I want to use jfets because they are self-biasing- and are low noise. I want to use them both as gain stages and current sources, yet keep the parts count low. I will probably custom-make my own pcb's for the modules should I choose to build them.
Old 17th September 2006, 09:18 PM   #4
poobah's Avatar
search for "folded cascode" & "Blowtorch"
Old 17th September 2006, 10:36 PM   #5
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Need help with discrete op amps.
...... especially since I saw all of the circuitry the AD-817 has in it.
Yes, in an IC op-amp can be 20-30 transistors! even in the less advanced
and signal may have to pass 7-8 transistors from input to output.
When I build a discrete preamp / op-amp
I not often endup with more than 8-10 T
and signal wont pass more than 3, maybe 4 devices.
You know there are 100 and 1.000 Op-Amps for sale and they are all different in some details, and in what they are intended to do, be used for.
It is same for building with discretes. 1.000 of possibilities.
So member poobah question is valid:
One of the first questions we need find an answer to:
What is the environment your discrete op-amp will live in?
Between a source and a load is where every amplifier is found.
A good description of those 2 factors, is what we start with.
This can be several different sources / loads to make your amp more generally useful.
But can also be a tailor made custom preamp for a very specific job.
Between for example CD-player Brand1-xxxx and Power Amplifier Brand2-xxxxA3
lineup one generally useful diyAudio member
lineup
Old 17th September 2006, 11:00 PM   #6
lineup's Avatar
A good example of what I wanted to tell about,
is in my topic about a preamplifier design for another Power amplifier.
I this post a member [ MIKET ] suggests Design Goals.
What we would try to work towards.
What specifications we wish for a resulting amplifier to have.
Design Goals. Pre Amplifier for SEWA 7 Watt ClassA
lineup starts a topic, once in a while
lineup
Old 17th September 2006, 11:03 PM   #7
johndiy is offline johndiy  Greece
Banned
in your case i would recommend you use a good op ic
or
you could use a simple class-a discrete op amp
john
Need help with discrete op amps.Hide this!Advertise here!
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 06:04 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 11:27 PM
Op-amps vs Discrete for preamps/DACs kop89 Solid State 4 1st July 2008 05:42 PM
Discrete fully differential amps and no CMFB rtarbell Solid State 1 24th August 2006 07:22 AM
Question about Discrete Based(Transistor) Amps? Tom D Solid State 9 1st September 2003 05:57 PM
Copyright ©1999-2017 diyAudio
