BOZ preamp project
BOZ preamp project
Old 24th October 2006, 01:42 AM   #51
likeDIY is offline likeDIY
After removing the resistors, I got voltage at C1 is around 80V, emitter of Q1 is around 60V, BUT, after about 10mins, the C2 is exploded. Definitely there is some shorting somewhere.
So I decided to redo it from begining which I will test as I go, and very careful about the short circuit. :-(
@Dzoli: Did you get the same problem as mine before you change to 22K?
Old 24th October 2006, 07:43 AM   #52
dzoli is offline dzoli  Hungary
After removing the resistors, I got voltage at C1 is around 80V, emitter of Q1 is around 60V, BUT, after about 10mins, the C2 is exploded. Definitely there is some shorting somewhere. So I decided to redo it from begining which I will test as I go, and very careful about the short circuit. :-(
Hello,
No, I relised that the current drawn form the the power supply was high on on channel. I had the possibility to compare the voltages between the two channels. Then I found the faulty 10K trimmer.
Zoltan
Old 24th October 2006, 07:49 AM   #53
bays_9a5tt is offline bays_9a5tt  Croatia
bays_9a5tt's Avatar
Hmm, electrolytic caps explode if they build excessive inner pressure. This may indicate reversed polarity on C2, faulty C2 or so...
I would replace C2 with new one, 100uF/100V.
After that, check voltages as previously mentioned. When you're sure about the supply, solder back R2/R3 and check. You might expect voltages similar to this
thread
Old 31st December 2006, 11:11 AM   #54
JC Fardo is offline JC Fardo  Brazil
JC Fardo's Avatar
Default Fun with Blackies
Originally posted by likeDIY
Hi guys, the output capacitor C103 =10uF can be changed by 22uF? Will the output frequency response changes alot?
Hi
Just for the record. Yesterday I replaced originals coupling 1.0 and 10,0 uF Panasonics to Black-Gate N 50V 1.0 and 4.7uF.
Well it really works. Improved highs and sound stage.
Recommended.
Happy New Years
JC
Old 31st December 2006, 01:04 PM   #55
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Those BG are e-lyts right?Still they sounded better than the Panasonics?
Regards Åke
Old 31st December 2006, 03:35 PM   #56
JC Fardo's Avatar
Correct. They sounded better.
They are non-polar elitcs and this confirm its good reputation
JC
BOZ preamp projectHide this!Advertise here!
..my little ecc82 preamp-project Mr. Triatic Tubes / Valves 25 8th April 2012 09:47 PM
The diyAudio.com preamp project! dorkus Solid State 291 16th September 2011 02:15 PM
Project Phono SE preamp Sunsun22 Analogue Source 10 17th December 2004 02:53 AM
Copyright ©1999-2017 diyAudio
