BOZ preamp project
BOZ preamp project
Old 16th October 2006, 04:42 AM   #21
likeDIY is offline likeDIY
Hi guys, the output capacitor C103 =10uF can be changed by 22uF? Will the output frequency response changes alot?
Old 16th October 2006, 06:12 AM   #22
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
It will go down, which is a good thing (-3dB from 3 to 1,5Hz nominal)
Mads K
Old 16th October 2006, 06:14 AM   #23
Nexus is offline Nexus  Netherlands
Hello likeDIY,
That will depend on the impedance which loads your BOZ.
You can calculate it out with:
Fc=1/2*pi*R*C.
where Fc= your freq response
R=the load impedance for your BOZ
C=10 or 22uF.
Best Regards:
Nexus
Old 18th October 2006, 08:18 AM   #24
Ok, I will give it a go with a 22uF.
The values of resistors must exactly the same as in the circuit? I'm abit lazy not to make the 33.2K and 22.1k, or 4.75K, in stead I just make it 33k, 22k, 4.7 respectively. Would it be much difference?
Old 18th October 2006, 08:22 AM   #25
Mad_K's Avatar
That's fine
Mads K
Old 19th October 2006, 02:45 AM   #26
Help help help.
It's blown up !!!!!
After connecting to the AC source, it's blown up :-(
The two resitors R2 and R3 are the first to get fire...
Please help, what is the problem? I'm quite sure that I connect the polar of the components correctly.
Old 19th October 2006, 05:37 AM   #27
Mad_K's Avatar
Your amp is drawing a lot of current! What sets the current is the voltage at the mosfet's Source and the source resistor; are R101, P102, and R108 correct value and placement? Or maybe you have a short circuit (to gnd) somewhere? Did you smoke any other components?
Mads K
Old 19th October 2006, 06:33 AM   #28
I think I should check the P102, how can we indicate the CW and CCW for the P102 as shown in the circuit?
As soon as it gets smoke, I disconnect the power, so hopefully no other things get burn.
Old 19th October 2006, 06:44 AM   #29
One more point, before making the PCB, I have mirrored the image and print it out, It might be a problem with the pin connection?
Old 19th October 2006, 07:13 AM   #30
Mad_K's Avatar
The pcb layout in the original article is bottom viewed from bottom. How did you make the pcb?
Mads K
BOZ preamp projectHide this!Advertise here!
..my little ecc82 preamp-project Mr. Triatic Tubes / Valves 25 8th April 2012 09:47 PM
The diyAudio.com preamp project! dorkus Solid State 291 16th September 2011 02:15 PM
Project Phono SE preamp Sunsun22 Analogue Source 10 17th December 2004 02:53 AM
