Hello! I just want to know if this is correct and if it not, can you say me what to do !!!!! This is for the ZenV4.
At the output of the diode bridge, I put 4 capasitor of 20 000uF-50V in parellele with an inductance of 1,8mH-18AWG. The inductance come from my old 2 way speaker! thank you ! |
#2 |
You put them like this: cap-cap-inductor-cap-cap.
But I dont know if 18awg wire for the inductor will be enough.. |
#3 |
Hello arold19,
You can use the circuit that is shown below. The parts are not critical, and you can use similar ones if you can't find those from the schematic, or if you already have similar ones. Best regards, Kristijan Kljucaric http://web.vip.hr/pcb-design.vip |
#4 |
Somebody know if I can include without risk my inductor 1,8mH 18AWG in the circuit of the power supplie???
thank you! |
#5 |
My (very old) electronics tables shows that 18AWH wire can carry 8A with a 10'C temp rise.
It also has a resistance of 6.4 ohms per thousand feet. Volt drop is proportional to current (specifically bias current): what's the DCR of your inductor? Nice one, David. |
#6 |
I don't know what is the DRC!!! If it is he value of the resistance, if is about 1 Ohm with my multimeter!
#7 |
But I saw on many project that people use some inductor with a very small wire... like 24 or smaller???
#8 |
For the bridge, can I take a IN4436???
| 40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? | dtm1962 | Solid State | 10 | 15th September 2011 07:38 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 02:21 PM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| Page generated in 0.08896 seconds (73.64% PHP - 26.36% MySQL) with 11 queries |
