UGS adventures
UGS adventures
Old 31st July 2011, 07:44 AM   #981
nar is offline nar
nar's Avatar
Originally Posted by Martin Strolz View Post
Good to read that some more fanatics have choosen this project. The UGS preamp is a very nicely and absolutely professionally developed and planned project, - thanks Francois! And thanks Manu for your support and encouragement! I have made my own boards, some were milled the rest was etched. Most stuffing and soldering is done already. Now I do the case and have started with the backplate. Here are a few pictures of my build.
Greetings to all, Martin
Very nice job and very careful work
Be careful the external lines on the UGS boards not to short circuit with the real V+ / V- tracks just nearby. I would remove that ext line totally with gentle abrasion process, but if no electrical short should be OK
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 31st July 2011, 08:35 AM   #982
Tiroler is offline Tiroler  Austria
Tiroler's Avatar
awpagan: No, not in this case as each heat sink carries just one transistor. All the heat sinks will be electrically life, but they are not connected to another part of the circuit via the board.
nar: Thanks for the hint. Yes, that would be a stupid mistake. Especially so, as I always strive for excellent quality.
Cheers, Martin
Old 31st July 2011, 08:58 AM   #983
awpagan is offline awpagan  Australia
Cheers, Martin
It's just not good work practice to leave the heatsinks live.
I'm using silpads on mine, and they are not overheating.
Allan
Indecision makes the world gone round.
Maybe
Old 31st July 2011, 09:31 AM   #984
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
This pre doesn't actually need sinks.
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 31st July 2011, 11:21 AM   #985
nar is offline nar
nar's Avatar
Cheers, Martin
I would remove the line, but if electrically not live, you may leave it
Allan
I also use sinks on the PSU, they get just get "gently hot"
One can omit the PSU ones; the UGS board heatsinks are essential to maintain very low offset at the outputs, thus permitting DC coupling with next stage, thisis one of the reasons we use this pre !!!
With the heatsinks temp is about 37 - 38 celsius
nAr
Old 2nd August 2011, 03:29 AM   #986
NYCOne is offline NYCOne  United States
Default First adjustment
I finished my UGS preamp boards. I have the "simple" version, just the UGS power supply boards and the UGS modules themselves (not the whole preamp with display).
Is there a document, or an explanation of adjusting the modules? I couldn't find one.
Old 2nd August 2011, 08:08 AM   #987
nar is offline nar
nar's Avatar
The procedure is simple : once module is powered, plug between any output and ground, adjust roughly VR1 20R to get 0 mV offset at the output. Then placing multimeter between the 2 outputs, use VR2 to achieve 0 mV differential.
You'll have to reproduce the procedure about 6-7 times to get both absolute and relative offset 0 mV, because the trimpot settings are interdependant. After one hour or so, it is the good moment to finetune all this. It can be faster if you use 2 multimeters at the same time, one for absolute, one for differential
One thought though : to get stable 0 mV offset, you'll definitely need the heatsink. Without, you can test the module and get about 0 mV at the outputs, but offset will wander. Some friend suggested that the heatsink could link the 2 double jfets and would be just sufficient; I chose to build the "total" heatsink just because I didn't know, and it worked fine.
Another hint is to plug and play the module without the RFBs in place, so if you have problems on the boards then the cause will be easier to troubleshout
I really hope you'll get some working modules at the first time. Mine played music instantly, and I was so happy with the sound, listening to my favorite test CD I could almost cry
In my opinion, with the UGS modules we get the absolute best of this jfet double pair amplification, freed from artefacts like noise, distortion, etc ... thanks to the double cascoding and the current mirror outputs, thus no external output load on the jfets. Supersymmetry does a royal "finish touch" on this, and the result is absolutely musical, with nothing artificial, perfect sense of rhythms and excellent respect of complex tone characters. But it is just a personal opinion
Best,
nAr
Old 2nd August 2011, 09:33 AM   #988
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
UGS adventures
...mine has been playing for almost 2 years now and i can completely agree with your appraisal nar.....just gorgeous music, of course make sure you have the best source.
This led me to redo the IV on my Shanling.....and build an F5......
Old 2nd August 2011, 09:37 AM   #989
nar is offline nar
nar's Avatar
Source is very important for sure !
I completely agree with your Shanling mod ... I/V stage is perhaps the node where any improvement is heard instantly.
I'll build an UP next, but will take some time ...
Best,
nAr
Old 2nd August 2011, 04:47 PM   #990
Best,
nAr
Thanks. I'll give it a try. I need to build a heatsink of sorts. I used double 2SK170 and 2SJ74 with BC550 and BC560 so the standard heatsink may be slightly modified.
I'd also become interested in Chas (Hifizen's) version of this circuit, but I'll try the standard first, then move to new things.
UGS adventuresHide this!Advertise here!
