UGS adventures
UGS adventures
Old 3rd May 2014, 01:21 PM   #1181
Maousse is offline Maousse  France
Hi there !
The Atmel is programmed using Ponyprog, via the JTAG connector.
Cheers
Old 3rd May 2014, 01:52 PM   #1182
Junie is offline Junie  Philippines
Hi Maousse, Mj777 has Atmel AVR programmer we will try to do it tomorrow.
Old 4th May 2014, 09:32 PM   #1183
Default update
We did flash the uC with AVR, HEX and EEP successfully loaded but not responding to switch (power) only indicator is a dim light in a power button.
I tried using the Ponyprog2000, it's successfully programmed but not working. Kindly help.
ATMEL AVR.
Ponyprog2000.
Old 5th May 2014, 04:35 AM   #1184
didiet78 is offline didiet78  Indonesia
Incorrect fuse bits ?
Do you change the fuse bit ? Or you just write hex + eep ?
Didiet
Old 5th May 2014, 04:54 AM   #1185
Hi Good morning!
I did Hex and eep only, how to do the fuse bits? apology I'm new to this programming thingy.
Junie
Old 5th May 2014, 05:32 AM   #1186
On your AVRISP MKII click fuses tab. Then enter low fuses and hi fuses.
Any info about fusebit on documentations ?
Maybe this file would help (in french)
Didiet
Old 5th May 2014, 05:58 AM   #1187
Yes I did use ponyprog2000 and succesfully loaded hex and eep but after the upload when i switch on it has no response.
Old 5th May 2014, 06:03 AM   #1188
The files contain howto program the avr for ugs. Have you read it ?
What tipe lcd do you use ?
Didiet
Old 5th May 2014, 07:04 AM   #1189
I patiently "google translate" the procedure to english
I'm using crystalfontz big lcd.
Old 5th May 2014, 04:52 PM   #1190
Audio4Fun is offline Audio4Fun  Chile
Default 2SK389BL IDSS too small
I had purchased one pair of 2SJ109BL and another pair of 2SK389BL from Littlediode.com on UK, they price is the more expensive on the market but it seems to me that they sell genuine JFETS.
After a 5 week shipping wait, I had received the JFETS for my UGS modules, the first was measuring IDSS using two multimeters and a single 9V battery using the schema on following picture, duplicated for this case:
The measurements I get are the following:
1) 2SJ109BL : 9.33mA & 9.21mA
2) 2SJ109BL : 9.70mA & 9.73mA
3) 2SK389BL : 7.15mA & 7.02mA
4) 2SK389BL : 3.59mA & 3.65mA
My problem is with the last one, its IDSS measurements are within GR grade as indicate Toshiba on the 2SK389 datasheet, but it’s labeled as BL grade. ¿Does this indicates that was a mistake at the factory when classifying the JFETS? ¿It’s common this type of mislabeled mistake? ¿Could be a fake or a relabeled JFET?
Thanks,
Alejandro
UGS adventuresHide this!Advertise here!
