UGS adventures - Page 111 - diyAudio
Old 13th February 2013, 09:35 AM   #1101
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
yeah
and you would hear that difference ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th February 2013, 09:55 AM   #1102
Zen Mod
would you please correct me If I am wrong
Is Z in of UGS V3 about R In when used with unbalanced Input and about 2 x R In when used with balanced Input
can I Increase R In If I need more UGS Z In because I like to lower output value coupling cap at source
Old 13th February 2013, 10:01 AM   #1103
Zen Mod's Avatar
yes , you can , but only up to some value
I would not go much above 47K
even if cascoded Jfets are in case , they don't like too much of impedance in feeding (feedback or not ) paths
Old 13th February 2013, 11:04 AM   #1104
thank you
would you please check out Z In values - are they correct
Old 13th February 2013, 01:13 PM   #1105
Zen Mod's Avatar
roughly - what's the value of series resistor , that's input impedance per leg ; that's precise enough for most purposes
inputs are inverting , ref to correspondent outputs ; so they're acting as virtual gnd (looking from preceding stage) and there lies the reason for that simplicity
you meant on that ?
Old 13th February 2013, 01:23 PM   #1106
thank you Zen Mod
so when used Pot before UGS the load for my source Is R POT parallel to R IN UGS
Old 13th February 2013, 01:47 PM   #1107
Zen Mod's Avatar
sort of
whatever - going much above 10K for pot is way to introduce cable irregularities in game
almost any decent source nowadays is having max output impedance in range of max 600R , so capable to drive 10K pot
if not , then quality of source in question isn't on par with UGS
Old 13th February 2013, 08:01 PM   #1108
rade95 is offline rade95  United States
Originally Posted by samoloko View Post
when using unbalanced mode UGS v3 with unbalanced In+ to unbalanced Out+ Is It correct to ground In- and Out-
at first I was using UGS v3 with not grounded In- and Out- then I grounded In- and Out- and got more gain but for me the sound become somehow unplesant
are R In and R FB and R G the most critical resistors which got to be of highest quality
UGS adventures
thanks samoloko, I know I saw that long post of Cheffs somewhere. It explains, well, almost everything. :-)
UGS pre, stock F5, PassLabs X2.5, Aleph P
Old 13th February 2013, 08:09 PM   #1109
Originally Posted by Maousse View Post
I use my Cheff's UGS All Inclusive in unbal/unbal config for now.
My amp has 29dB gain, that makes 1.2V sensibility.
Cheff's UGS gain is enough for my configuration, I guess it could be OK for you too.
About PCB's, the Gerber Files are on the site liked on my previous post. But cost can be high for just one set. I have a spare full set if you need (I keep it for my old days ^^)
Maousse, I would like to buy that spare set of PCBs. Please let me know and PM me. Looked at the gerbers, still cannot find UGS module and the UGS PS (+-24V dual) gerbers. What file names I should be looking for? The thing is I would like to re-design the PS PCB so that it can fit a non-EU transformer like the one you see in my PS picture. Also it would be nice to re-design the pin layout of the UGS module so that we could fit single JFETs instead of those hard to find duals. What do you think?
Old 14th February 2013, 11:41 AM   #1110
Maousse is offline Maousse  France
rade95, you've got PM
Gerbers for Cheff's All Inclusive version is at http://psykok.dyndns.org/diy/preamp_.../GerbersCG.zip
Simple version (the PCB you actually have) are at http://psykok.dyndns.org/diy/preamp_.../UGSGerber.zip
Copyright 1999-2017 diyAudio
