#1041 | |
Should be ok for ST Microelectronics regulators with spec: max. 35 Volts input. I had that "ST" regulator in the board for one year before the amp stopped to work. I will put a new one of the same type in as next step. Regarding power consumption: Layout is: Transformer 24V AC 8VA => 7809 regulator => uC board with 7805 regulator => Atmel CPU & VFD Display Atmel Atmega64 specification says consumption between 200 to 400mAmps. Newhaven VFD M0220MD-202MDAR1-3 consumes 290 to 435 mAmps. Total: 490 - 835 mAmps *5Volts = 2.5 to 4.2 Watt. On top of that comes dissipation of the 7809: ( 33Vin - 9Vout) * 490mAmp = 11.8 Watt ( 33Vin - 9Vout ) * 835 mAmp = 20 Watt Total: 14.3 to 24.2 Watts power draw, clearly exceeding the 8VA per side rating of the transformer. So, maybe the transformer is the root cause of the problem. I noticed also in past year the power supply got quite warm when in operation.... I wonder why not many of the other UGS builders in France have same problems....many builds were made according to same BOM / Layout. What kind of Display and central Transformer do you use in your UGS ? Last edited by dsdjoy; 4th February 2012 at 09:18 PM. |
#1042 | |
![]() Which is not so power demanding ... And on the PSU side : 12V relays to avoid the reg problem ... (the first one was running 24V relays without problems though) Trafo is 16VA (ERA EI54 or block) from Reichelt if I recall right (I am not at home right now and can't check) Hope you solved your problem .. ![]() Manu
Manu, masked agent of entropy & ZMs Čiko |
#1043 |
Hi all!
Does anybody have crystalfontz display (CFAH2002L) they would like to sell? Thanks |
#1044 | |
#1045 |
dsdjoy
thanks a lot! |
#1046 |
Hello,
I'm lookink for UGS PCB. If someone has spare, let me know! Thanks; |
#1047 |
Wow, Martin! That is an EXCELLENT build!
I would certainly be interested in a remote volume board if they are available in some manner! I've been looking for a good remote unit for use in an upcoming DCB1 build...
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages. |
#1048 |
Thanks Eric! I know that there is a lot of interest amongst UGS builders for a bespoke remote. Cheff DeGaar is the man that could develop that..! Guess we have to wait.
Martin |
#1049 |
Tried, tried, but no success yet.
I rebuild completely the Logic/Relais section in power supply. The Mikroprozessor board is working again...yeah....but the relais boards are not working. First I checked the Mikroprozessor. This one was ok, it switched it outputs between 0V and 5 Volt. Then I checked the power supply for the Relais boards. Voltage breaks down from 24 Volt to 2.3 volt. I inserted a 10 Ohm resistor into the 24V supply line for the Relais boards. measuring 10Volt across the 10 Ohm resistor ! My math says that the relais boards are consuming too much current (1 Amp)- and voltage from 7824 regulator breaks down. (I have only 1 channel out of two relais boards connected). I measured coil resistance of all relais . All are around 2.7 to 2.9 kOhm. So no short circuit here.... There are 3 Darlington Array Chips on the Relais board, which switch the relais. I was thinking that maybe those chips have a short circuit. I unsoldered all 3 Darlington Array chips (ULN2003, ULN2803) from one relais board. I then inserted a brand new ULN2003 DIP16 into the socket of 1 board. This Dip16 socket chip is responsible only for switching 3 relais. I did NOT solder the other two Darlington Array chips to the board which would handle volume and input switching. I then connected the single (one out of two channels) board to Mikroprozessor board and supply. Same effect: The single, new ULN2003 chip consumes 1 Amp current (max. that the 7824 delivers) and gets very hot.....was there some smoke... ? I am lost....what is wrong here ? Schematic: http://psykok.homelinux.org/diy/prea...urs/Atours.pdf PDF page 2: I did connect only one side. In the end for testing purposes only IC2 soldered (not IC1, IC3). Last edited by dsdjoy; 30th April 2012 at 05:32 PM. |
#1050 |
it look like a short circuit. What is with the capacitors at the relay coils? Dan |
| Page generated in 0.12405 seconds (78.24% PHP - 21.76% MySQL) with 11 queries |
