UGS adventures
UGS adventures
Old 25th October 2011, 10:55 PM   #1001
dsdjoy is offline dsdjoy  Germany
Default UGS Frequency Response
here is a Audio Precision Frequency Response measurement of my UGS all-inclusive build (all-inclusive means PCB set including volume control, input selector, CPU and display boards from french HCFR forum).
The measurement was provided as a free-of-charge service by Mr. Fuchs from Volpe-Audio Electronics - electronics development at the Analogue Audio Association event in Krefeld/Germany. Thanks a lot for the nice talk and measurement session !
Measurements revealed that the frequency response is flat between 10hz and 80khz (-3dB point with 2V input and 2 Volt output)
Frequency response of UGS Preamp shows dependency on the volume setting.
Cause is probably parasitic capacitance (here: Vishay Dale CMF-55) of the resistor network - maybe to some extend also switching relais or PCB circuits.
Red Line: Volume attentuator set to 0dB - no attentuation.
-3dB point is beyond 200khz.
Other lines: Frequency response at different volume levels. -3dB point varies with volume level with minimum at 80khz.
Based on a lot of listening sessions, my impression is that the preamp sounds very neutral - the difference between the amp and amp-bypass at same loudness is minimal. But I also find that when bypassing the amp - or when setting volume attentuation to 0db (none) - the sound is a bit better.
Not sure where to look for, but the volume attentuator resistor ladder and relais circuits could be an option........
Old 25th October 2011, 11:09 PM   #1002
Default UGS THD+N
here is a Audio Precision THD+N over frequency measurement.
THD with 500khz Bandwidth is ~ 0.004%.
As this distortion curve is independent from frequency, it seems to be dominated by background noise.
Limiting the bandwith and excluding the high-frequency portion of the noise result is:
THD with 22kHZ Bandwidth is ~ 0.001%
I am not an expert in THD figures of preamps, but I'd say it looks very well...
[Measurement kindly done by Mr. Fuchs from www.volpe.at]
Old 25th October 2011, 11:13 PM   #1003
Default UGS CCMR and FFT measurement
Last but not least the CCMR and FFT measurements:
Common Mode Rejection
Common Mode Rejection on the symmetrical input is around -60dB.
Not too bad, but maybe some even better matching of transistors and some resistors is required here to lower CMRR ?
FFT with suppressed ground/base wave
Residual 50hz AC-line-noise is at approx. -100db - looks fine.
FFT shows some -115dB noise at 5.9khz and it's K3 at 17.7 khz.
There is a small noise-generator hidden somewhere in my circuit layout.
Measurements with different inputs and separate ground-reference of the audio-precision
indicate that there is a grounding problem in my layout.
However at -115db level of this noise - it is probably not really audible on the speakers ?
Old 26th October 2011, 08:30 AM   #1004
nar is offline nar
nar's Avatar
Very nice and useful measurements. Thank you very much
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 26th October 2011, 07:43 PM   #1005
philbyx is offline philbyx  France
philbyx's Avatar
Ouahouh!!!!
Many thanks Dsdjoy for these nice measures!
Cmrr is finaly not so bad!!!
Old 28th October 2011, 09:17 PM   #1006
Originally Posted by philbyx View Post
Ouahouh!!!!
I am getting convinced too, that this preamp measures (and it also sounds) better than many (and most) commercial preamps. Thanks a lot here to CheffDeGaar, 'Flat' from HCFR forum and last but not least Nelson Pass for this great preamp !
BTW: Now my speakers are the limiting factor....more DIY things to do....
Old 9th November 2011, 09:58 PM   #1007
daltvi is offline daltvi
Default 2SJ109, 2SK389
want to build UGS modules where can I buy jfet 2SK389 and SJ109?
Old 9th November 2011, 10:40 PM   #1008
nar is offline nar
nar's Avatar
Use matched substitutes, K170bl /j74bl
Old 10th November 2011, 09:15 AM   #1009
Thank
Old 10th November 2011, 10:33 PM   #1010
Default k170bl/j74bl
where can I buy K170bl/j74bl original Toshiba ?
UGS adventuresHide this!Advertise here!
