I am sorry if this is a old point. But I am wondering what is the benifit of using large die mosfets ie:610, 9610 vs. small signal mosfets?
#3 |
I think jjacks4x means why medium power fets for small signal use.
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#4 |
Account Disabled
Probably, it is to get a good fit for designer's purpose.
If the size gave any benefit, it would be a second thought. JH |
#5 |
Well, OK, but the larger die's are used to get Ron down, but it does increase capacitances and lower bandwidth. For small-signal uses, normally the Ron is less important but the wider bandwidth is a plus. So each of the parts has a place where it is best suited.
Jan Didden |
#6 |
Good morning! IMHO: 1) the noise floor is lower. 2) devices with higher transconductance lead to less distortion without feedback. Uli
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#7 |
Thank you all for the info. My real motive is project size. I am redoing a sacd player and want to do a susy buffer stage. So using the "What did Nelson do method" I see only large die mosfets. And before I build something I like to get peoples take on different ways. Keeping the parts small is helpfull but sound is the most important to me. I just wondered if you could still get same sound style out of small die units?
Thanks again John |
#8 | |
The one and only
drive and linearity. |
#9 |
The fet I used for the low level part of my class A, an ST P3NB60 ( have lots of them, no other reason) is a TO-220 only good for a couple of amps and 600v, but at 50mA and Vds of 75v at 150v supply will swing 80v p/p with no visible distortion and 100v p/p with almost none, and is 3db down at 7MHz IIRC.
#10 |
there have been Mustang engines of 390, 392, 427, 428 and 429 cu inches, but no 402 (=6.6 L).
| What mosfets to use? | seafire | Solid State | 18 | 25th March 2009 09:44 AM |
| Where to buy MOSFETs? | goodas | Solid State | 26 | 15th June 2008 08:55 PM |
| n/p Mosfets vs depletion mod mosfets | marcello7x | Car Audio | 6 | 4th October 2006 05:01 AM |
| Why no MOSFETs? | Pbassred | Solid State | 25 | 1st February 2004 08:06 PM |
| hmm.. help with mosfets | Colt45 | Solid State | 5 | 27th August 2002 07:08 AM |
| Page generated in 0.09993 seconds (76.98% PHP - 23.02% MySQL) with 10 queries |
