Old 7th September 2006, 12:57 AM   #1
Send a message via MSN to tze-hao yen
Default water cool for aleph-x?
hi every body after i did my aleph-x i find out that is too hot to touch so do any body try water cool it?
Old 7th September 2006, 01:18 AM   #2
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
This has been done to alephs before. Grey Rollins had a nice thread about it . Use the search function and you will find them....
Remember, you are supposed to search before posting.....
Old 7th September 2006, 01:24 AM   #3
i tried but there is no math for the water and aleph -x so can any one just tell me where to looking for it ?
Old 7th September 2006, 01:41 AM   #4
so do you think that will be an good ideal to have the water runing one the copper pipeand then put the pipe on the heat silnk or have the fet mount on a water cooling aluminus plate like the one we have in restaurant ? you know the one we find on the botton of the ice ? they use it to cool coke cola or pepsis
Old 7th September 2006, 02:52 AM   #5
diyAudio Editor
Variac's Avatar
Grey Rollins talks about soldering a copper tube to a 3mm copper plate
and mounting the devices to the plate. I'll try to find it . It is for an Aleph not Aleph X, but it doesn't matter.
Old 7th September 2006, 02:56 AM   #6
imix500 is online now imix500  United States
Proud Union Member
imix500's Avatar
If you need parts I have a bunch left over from some water cooling projects, let me know and I can put them in the Trading Post. (Hope this is the less frowned apon way to do that)
Old 7th September 2006, 03:06 AM   #7
diyAudio Editor
Variac's Avatar
seems like
Water Cooled
and
Water Cooling
are good to search on. There are more than these...
Water cooled audio circuitry
Water cooling, practical matters.
Water Cooling
Old 7th September 2006, 05:34 AM   #8
EUVL is offline EUVL  Europe
Since you already have heatsinks, the easiest way to reduce temperature (before trying something more complicated) is to force cool them. Just get yourself a few low-noise 120mm computer fans and blow them at reduced voltage against the heatsinks (at least one fan per heatsink, two would be even better, as you can reduce fan speed and hence noise futher). Use a variable power supply to try until you get acceptable temperature. You would not hear much fan noise at reduced speed.
And then you have all the time in the world to think of other fancy alternatives.
Patrick
Water-cooled Aleph idea MEGA-amp Pass Labs 70 12th March 2011 12:52 AM
What, oil and water don't mix now?! Wha' DIYa know? Full Range 9 26th May 2009 12:07 AM
2kw water cooled amp diya370 Solid State 16 29th December 2007 11:29 AM
Water cooled plate on ebay (possible water cooled amp application) BrianGT Parts 1 27th May 2002 03:19 PM
Page generated in 0.09103 seconds (76.49% PHP - 23.51% MySQL) with 10 queries
