Another Zv9 completed
Old 30th August 2006, 04:52 AM   #1
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Another Zv9 completed Send a message via AIM to Peter Daniel
Default Another Zv9 completed
Here's my version of Zv9:
It is a very good sounding amp.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th August 2006, 05:14 AM   #2
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
Default Re: Another Zv9 completed
Looking nice.
What is the difference in sound compared with your gain clone?
Old 30th August 2006, 06:08 AM   #3
I'm using the amps with Fertins 20 EX which are approx 100dB efficient. Zv9 has much less gain than GC, I can connect NOS DAC directly (2V ouptut) and the sound is about normal listening level.
I only had it on for few hours, so it's hard to draw any conclusions. First impression is that it sounds softer, with less bite and less edge. How desirable it becomes, I will write in a week or so. Beside that, tonality and detail are very similar.
BTW, I didn't switch from GC today, I had Dick Olsher's T-Rex 300B amp in my system last few days. It is a pretty good amp too.
www.audiosector.com
Old 30th August 2006, 09:54 AM   #4
SMathews is offline SMathews  United States
Looks good.
A few questions :
Did you solder the JFet?
Is that a copper plate that all the Fets are attached to?
Is there anything between the plate and the heatsink?
Alot of screws to attach the plate and I see you didn't use the PS board.
Simmonds
Old 30th August 2006, 02:12 PM   #5
Yes, JFet was soldered to a small copper plate that is attached to the main plate.
The copper plate is 1/8" and acts as heat spreader/ heatsink damper. I used thermal grease to improve transfer.
PS board couldn't be used here, as it is designed for different caps.
www.audiosector.com
Old 30th August 2006, 02:19 PM   #6
t3447ml is offline t3447ml  United States
Looks like a very nice build. I have a couple of your boards and hope to have my ampilifier completed this winter. Once again thanks for making this hobby accessible to me. I have a couple of questions.
In the first photo it appears that resistors R1 and R6 were left out. I can understand R1 being left out so that a value can be selected later to obtain lowest distortion. However why is R6 left out?
What is the size of the heatsink? I am planning on a heatsink measuring 6" x 12" x 2.75" fin height for each channel, do you think this will be sufficent?
Thanks.
Old 30th August 2006, 02:30 PM   #7
I was using 5W Mills resistors, so instead of 3 x 3W Panasonics I decided for 2 x 5W . The combined resistor value stays the same.
The heatsink is 11 x 11 x 2.25 . It is just about the right size. I used 300VA, 2 x 19V trafo and the actual voltage (with 0.27R resistor between caps) is 52V.
www.audiosector.com
Old 30th August 2006, 03:13 PM   #8
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Thanks for sharing your implementation of this amp Peter. It's always
very interesting to see your ideas unfold into an amp.
I bet you were wondering if you'd ever get to use any of your R-Theta
heat sinks again!
Looking forward to the follow up in a few weeks.
Was the T-Rex amp your build, or a loaner? I don't think we've seen
how you'd build up a tube amp.
m.
Old 30th August 2006, 03:20 PM   #9
I try to use different approach to chassis building these days. Appearance is always secondary and form follows the function. If the idea of function is clearly defined, the form is not too bad either
The transformer was initially intended to sit flat on a bottom bar, but it came too close to the circuit so I decided to mount it vertically.
T-Rex was built by someone else, but having the taste of 300B I will definitely build a tube amp myself as well. I still don't know which one though.
www.audiosector.com
Old 30th August 2006, 06:43 PM   #10
metalman is offline metalman  Canada
metalman's Avatar
Beautiful build as always Peter. I must learn your secret of finding the time and money to build so prolifically. You've earned the same comment I made to Planet10 recently regarding his Frugel Horn developments:
Peter: Quit pressing my woo-woo button! I've got too many incomplete projects on the go already!
Seriously though, next time I'm in your part of the country I'll have to arrange a visit to your listening room.
Cheers, Terry
Another Zv9 completedHide this!Advertise here!
25w amp completed pudge667 Solid State 2 9th May 2007 08:57 PM
I completed my amp! peppennino Tubes / Valves 21 6th May 2006 03:29 PM
first completed sub chainenoble Subwoofers 4 11th June 2005 05:23 PM
HELP! Completed sub is bad! pne123 Subwoofers 20 17th February 2004 10:34 AM
Copyright ©1999-2017 diyAudio
