Another Zv9 completed - Page 2 - diyAudio
Old 30th August 2006, 07:48 PM   #11
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
Peter cheated this time;
he used U bar for connectors,instead of solid chunk of Alu!
Ugly!
Veeery ugly!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 30th August 2006, 11:06 PM   #12
The one and only
Nelson Pass's Avatar
Beautiful as always, Peter.
Old 31st August 2006, 03:43 PM   #13
steenoe is offline steenoe  Denmark
steenoe's Avatar
Peter, those amps are looking incredibly good, indeed
I had hoped for your oppinion on the nonpolar BG's versus film caps, hope you find time to get around to do a test.
Steen
Old 31st August 2006, 06:41 PM   #14
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Thanks guys, especially to Mr. Pass for inspiration.
Steenoe,
I see no way to install 100uF film caps in place of BGs.
I did comparisons of films vs BG N in DAC coupling and I could only find one type of cap that was better in that particular application: it was teflon V-Cap, everything else (Jensen copper, MIT RTX, Hovland, Siemens MKV, Russian PIO, Woner Cap, Infini Cap) didn't perform how I like it. However, I was not looking for a sound that was impressive, but one that is true and convincing.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 31st August 2006, 07:17 PM   #15
steenoe's Avatar
Ofcourse I was thinking of the bypass caps The 10 uF's
Steen
Old 31st August 2006, 07:32 PM   #16
You may find this post interesting then: http://www.diyaudio.com/forums/showt...500#post491500
www.audiosector.com
Old 31st August 2006, 08:24 PM   #17
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Peter,
How hot does the binding post and input RCA get? I noticed you didn't decouple the angle alluminum from the copper plate.
Did you source the copper plate from Metal Supermarket?
thanks,
m.
Old 31st August 2006, 08:38 PM   #18
Yes, the copper plate is from Metal Supermarkets.
I was also concerned with temp of aluminum angle, but because of small gauge it does not transfer heat well, so RCA and binding posts are only slightly warm.
www.audiosector.com
Old 2nd September 2006, 03:08 AM   #19
Gooch is offline Gooch  United States
Gooch's Avatar
Great looking amp very original
Dave
Old 2nd September 2006, 01:50 PM   #20
very nice work peter !
can you give us please some hints about
the high quality parts ?
Greetings from Germany
Jürgen
25w amp completed pudge667 Solid State 2 9th May 2007 09:57 PM
I completed my amp! peppennino Tubes / Valves 21 6th May 2006 04:29 PM
first completed sub chainenoble Subwoofers 4 11th June 2005 06:23 PM
HELP! Completed sub is bad! pne123 Subwoofers 20 17th February 2004 11:34 AM
Copyright ©1999-2017 diyAudio
