One more mini Zen... almost!
Old 17th September 2006, 02:45 PM   #11
lineup is offline lineup  Sweden
lineup's Avatar
hi
I agree with Babowana.
Hum is the sound of remains of 50Hz ( 60Hz ) from MAINS AC.
Sometimes, Often! ... this is doubled to 100Hz ( 120 Hz ) after rectification and power supply filter.
Amplifier amplify.
So even quite low levels of this 100 Hertz
reaching input
will be possible to listen to, hear, in speakers.
When is a hum
we will try to see: in what improper way is Sound of TRAFO
getting into contact with INPUT transistor.
Sometimes, in small boxes,
and especially when you use NOT toroid trafos
it can simpy be Trafo being too close to amplifier board.
Or too close to some wire, that is connected to input.
Babowana is having a fair idea of the cause.
Based on what we can read in this forum,
9 times out of 10
-- this hum is is transported
via GROUND ( 0 volt ) wires or PCB tracks or Metalbox, amplifier case
from TRANSFORMER ....... to INPUT of amplifier.
Cutting and re-arranging 0 Volt / Ground wires
will fix these issue quickly in those 9 cases.
Case number 10 out of 10 is the more mysterious one.
But also this will be solved, if not by brain and experienced helpers,
so by trial-and-error method for fixing.
lineup - haikku haikku
lineup
Old 17th September 2006, 05:33 PM   #12
r_jik45 is offline r_jik45  Japan
Thanks to both of you for your suggestions/comments.
For the 0V - signal ground connection, it seems that they are also connected on the original board proposed by Tortello. I will try to see if I can 'cut' it somewhere... even if I do not really know how to make the difference between them
Regarding the position and possible interaction/interference between the 50Hz source and the inputs: I will try to isolate them better. The transfo is indeed close to the inputs... but there is not much space to do organize the parts another way.
And what about the fact that the input-ground is connected directly to the potentiometer? Is it normal that way?
Anyway thanks again
Old 18th September 2006, 03:28 AM   #13
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
The attached sketch might help . . .
Whatever their sizes are, R is R and I is I . . .
And, AMP's role is amplfying the samll v=ir into bigger . . .
Old 19th September 2006, 10:39 PM   #14
Hi Babowana,
I see: a star-ground has to be a real star.
I thought that something like what is presented on the right side would be ok
I will try to arrange the wiring as soon as I have some free time.
Thanks again!
One more mini Zen... almost!Hide this!Advertise here!
Mini-A PCB'S sandstorm33 Pass Labs 3 24th March 2008 12:39 AM
the Very Mini Magico Mini zei Multi-Way 7 11th February 2008 09:10 PM
My new mini-A. I really like it! mpmarino Pass Labs 20 3rd August 2005 03:37 AM
New Mini MikeW Pass Labs 39 7th June 2004 03:10 PM
Copyright ©1999-2017 diyAudio
