hello
I would like to know that they are the power supply that you built for a Zen V9. which power for the transformer? 300Va / a mono block, it too or not is enough ? a common or separate power supply? there is til a tolerance on the tension with the rail? (+/- 10%???) I seek a good compromise not too expensive! Thanks Phill excuse my English!
small handyman |
#2 |
The one and only
It's not very critical. I'm using a 36 transformer, and each channel
works at about 80 watts or so, so 300 VA will do the job. |
#3 |
Thank you Mr Pass
I will use 1 transformer 2x35 / 500 va in stereo another question: I have caps of 15.000µF. Can one use them in C1? Thank you Phill
small handyman |
#4 |
hello
I finished my Zen V9 : http://domainedupossible.free.fr/pag...ENV9/zenv9.htm it makes beautiful music the supply voltage is a little low : 46.5v is this prejudicial? thanks Phill
small handyman |
#5 | |
and looks beautiful too! Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog |
#6 | |
Hi Phill. That is a nice amp, clean and tidy. Good job
Happy listening. Steen
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 23rd April 2011 11:48 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Can i use a computer power supply to power audio amplifiers? | destroyer X | Solid State | 91 | 25th September 2006 04:36 AM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 02:21 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.08204 seconds (73.45% PHP - 26.55% MySQL) with 10 queries |
