Old 24th August 2006, 02:21 AM   #1
TJ is offline TJ
Default Power supply question for Aleph 2
Hi , i know this type of question been ask so many time but i still cannot find a good solution hope someone can help me .
(My transformer spec : pri 110v - 0 110v - 0 , sec 35- 0 35 - 0 )
UK wall socket 230v/240 50Hz
Problem :
1, how to connect the CL-60 ? Which is the best or hv u got any better ideal ?
Old 24th August 2006, 02:25 AM   #2
MEGA-amp's Avatar
The top one should be just fine, or the bottom depending on how you're looking at it.
Old 24th August 2006, 02:31 AM   #3
TJ is offline TJ
2 , As u can see my transformer is 110 - 0 been connect in series to 220 Vac . In Uk is 230/240 will this cos a problem ? How many voltage will rise/drop in the sec ? cant get a hi power inverter . or just use it dont care ?
3, The original in the Aleph amp is Panasonic Cap and discontinue . wht type of cap use in the AX series ?
4, can i use 47000uf / 50v Panasonic ? this is the only i can get in UK .
Old 24th August 2006, 02:49 AM   #4
MEGA-amp's Avatar
2. 120 or 220, one CL-60 in series with the live line should be OK
3. Are we talking about the Power Supply or the Amplifier Board?
You can purchase Panasonic at Digikey in the US, not sure about them being discontinued.
4. 50V caps is close to the edge, but should be OK.
Aleph P.17 Power Supply Bengali Pass Labs 6 6th October 2008 06:24 PM
Aleph 2/4 Power Supply Question onewhowaits Pass Labs 8 5th September 2006 08:21 AM
Big supply cap question (Aleph X) SY Power Supplies 0 20th July 2005 12:02 AM
Aleph 2 power supply caps question MikeZ Pass Labs 0 20th October 2004 07:55 PM
aleph x power supply question audionut Pass Labs 2 1st July 2003 02:03 PM
Page generated in 0.07055 seconds (74.30% PHP - 25.70% MySQL) with 11 queries
