Threshold Model FET one - STASIS Lienear State Pre-amp.
My Pre-amp has failed today and continualy blows fuses now. Has anyone had a similiar problem or known suspect components, or anyone have a schematic of the power supply? regards Richard |
#2 |
The one and only
Power supply capacitors would be the first thing I would
replace, and also all the tanatalum and electrolytic power supply decoupling capacitors on the boards. |
#3 |
Main filter caps replaced and all decoupling caps replaced with elna cerafins. Checked all power supply diodes bridge etc, the 2 Stasis transistors in power supply and measured all film caps as ok.
Problem still occurs and blows main fuse on power on, Anyone seen similar fault before on FET-1 or schematic of the power supply? Thanks on help so far |
#4 |
Banned
you have some sort of short circuit check main amp
module regards |
#5 |
Not very likely but you may have a short on the primary of the power transformer especially if the fuse blows immediately after you turn on the preamp.
Check with an ohmmeter and see if you have some resistance and not a short. |
#6 |
Banned
to really see if thats the case disconnect the secondaries
and switch on regards |
#7 |
Special thanks to everyone for there help. This is the first time i have found a transformer failure. All new elna Cerafins replaced in the amp. The fault ended up being the transformer. All is now working fine and the 500ma fuse is rock solid.
Thankyou Transformer specs are: AVEL-LINDBERG 15VA Toroid Transformer (encapsulated) Type 40/3034 Max load 7.5A per winding primary has 2 * 115v windings secondary 0 20v 0v 20v Still Available from: 47 South End Plaza New Milford, CT 06776 860-355-4711, ext 41 fax 860-354-8597 www.avellindberg.com $65 US |
| Threshold Stasis Model 3 | DLJunkie | Pass Labs | 60 | 23rd August 2011 09:09 PM |
| Threshold (which Model)? | BUGELSKI | Pass Labs | 8 | 30th July 2008 07:56 PM |
| Pre amp fault | Addolff | Parts | 4 | 6th January 2008 01:55 PM |
| THRESHOLD unknown model ??? Clue please anyone? | Thurax | Pass Labs | 5 | 4th November 2004 03:42 PM |
| Page generated in 0.08246 seconds (75.66% PHP - 24.34% MySQL) with 10 queries |
