I noticed that with my home built Aleph 3, one of the output mosfets (not the current source mosfet) is much hotter than the others. I had matched the mosfets, but evidently did not do a good enough job.
The solution is to take the mosfets out, and put in a better matched set of mosfets....But in the mean time, is there anything I can do, like changing a resistor, to make the output mosfets share the load better? I'm afraid that running the amp the way it is, will cause a failure in the hot mosfet leading to DC current finding its way to the speakers causing an expensive accident. Any advise is greatly appreciated.... |
#2 | |
diyAudio Moderator Emeritus
-- Brian |
#3 |
The one and only
You don't say how much hotter. I suggest that you
measure the DC voltage across the source resistors of all the Mosfets and report back. |
#4 | |
On Hiatus
to the working condition they will operate UNDER Otherwise you can measure and adjust until they fits fairly good together as the boys already have told you this is my any advice a lot of good ideas, not only my idea but Nelson and the others, in the thread here, I searched and found him an old technique there are several schematics ask before you use them, just in case Nelson's will work safely to 100% matching of mosfets there are several schematics ask before you use them, just in case Nelson's will work safely to 100% FUZZY on Matching FETs |
#5 |
The hot mosfet is quite a bit hotter than the others...On its source resistor I measured a voltage drop of .95v the other resistors had voltage drops of around .45v. I measured the current going through the hot mosfet and it was 1.75amps while the other mosfets measured around 1 amp.
Until I rematch the mosfets, is there anything I can do to bring the current draw down for this one mosfet? |
#6 |
I think you could place another source resistor in series with the one on the hot FET. This should reduce the current of the FET.
| problem with R44 on Aleph P 1.7 | Stefanoo | Pass Labs | 15 | 9th October 2007 12:57 PM |
| Problem with aleph p 1.7 | gabflo | Pass Labs | 7 | 2nd September 2006 05:50 PM |
| Problem with Aleph 2 | ppesa | Pass Labs | 1 | 31st January 2006 07:44 PM |
| Aleph 2 problem!Help... | nar | Pass Labs | 14 | 1st June 2003 03:42 PM |
| Aleph 5 PSU problem please help? | xsnailx | Pass Labs | 10 | 4th March 2003 06:28 PM |
| Page generated in 0.08334 seconds (78.94% PHP - 21.06% MySQL) with 10 queries |
