I searched for "T amp" and found threads under all the sub amplifier forums, so please forgive me if this is in the wrong place.
I want to know if this amp http://www.partsexpress.com/pe/showd...number=300-952 could power these speakers. http://www.polkaudio.com/homeaudio/products/r30/ I bought the polks on outlet for my gym, but we moved to a larger place and the amp I was using is too far away and hooked up in a totally different place in the house. The use is for a gym and I would be plugging a MP3 player in to it. I don't need anything insainly loud, just loud enough to hear over the noise of a treadmill. |
#2 |
The manual says they get 89dB / watt, which is fairly efficient. I think it would be ok depending on how loud your treadmill gets.
The actual power output of the T-Amp is 8W / channel driving 8 Ohm speakers, btw. This thread belongs in the Class-D amplifier forum, where you find lots of discussion on the T-Amp. |
#3 |
Thanks for the information. I think I might just get it. Two acually. I have some (don't laugh) bose for the bed room and they need a amp too. They are good enough to sleep too and I bought them over 10 years ago. We've all made our mistakes
The tread mill is pretty quiet. I was acually using computer speakers that had a baby sub, but I want to put that back in the garage so I can have some tunes while I work on the car. I got some long projects comming up and I just have to listen to music while I'm working. If a mod comes along, please move this to the correct forum. Thanks |
#4 |
9-10W is maximum into 8Ohms for the Sonic Impact. It produces about 5 useful Watts. It's real Watts, but still just 5. I would say Polk is correct when they say <20W.
I would go for an LM3875 chip amp. Cheap and easy to build. A 24-0-24V (100W) transformer will give you 2x25W@8Ohms |
#5 | |
Anyway, I already ordered it. I'll let you know how it turns out. I think it will work. If not, I acually have a 20 watt solid state healthkit amp that I was going to use, and it does work, sort of, but the volume and balance knobs are not working right. They have a short in them. At 20 watts, the speakers were much louder then I expected and sound was really comming out of only one speaker. I was going to fix the old solid state amp (and probably will in time), but I needed a quick and cheap fix. The old amp acually sounds decent, but it needs to cleaned out and checked over. It would take hours that I don't have right now. Hopefully I just need to hunt down a short. I hope the knob doesn't need to be replaced. It doesn't feel loose or sloppy, it's just that the sound crackles all over the place if you try and move it and the sound stopes comming out if you touch it the wrong way. It was a freebie. |
#6 |
At 9-10W the SI produces about 10 pct distortion. At 4W it's 0.2 pct.
#7 |
I did do a little research before I bought this amp and I read some good reviews. I was worried about it not being able to push the polks, but after reading a lot of reviews, I think it will work.
Some of the reviews are almost unrealistic as these cheap little amps are getting MAJOR praises. Amazon has a lot of reviews. Some bash the quality while others praise it. Some people simply hooked it up wrong and fried it. I think a lot of people used the wrong power adapter for it. I tried to find a cheaper one, but I couldn't find anything cheap that was in spec of what the amp wants. One good review is from here. http://www.6moons.com/audioreviews/sonicimpact/t.html *WARNING* link is not work safe due to some of the advertizing on the site. I ordered power adapters them it so I don't have to always use batteries. http://www.partsexpress.com/pe/showd...umber=120-1135 |
#8 |
I'm a big fan of the SI. I second everything written about it. With my old Altecs with a sensitivity of 96-98db, it's more than enough.
For every 3 db less you have to double the Watt. So 20W into your speakers is roughly 4W into mine. I'm not trying to scare you off or anything. None of us knows for sure until you've tried it. I hope it will work out. |
#9 | |
Ya, it will probably be close. I hope I didn't make a mistake. I read one good review from someone that had 90db speakers and mine are 89db, so it will probably be close. Also, from some of the reviews I've read, it sounds like it runs stronger/better from a power adapter then from batteries. I'll update how it works when the stuff comes in. I acually bought two and I know for a fact that it will work with the bose I have. I'll test it on the polks and if it just doesn't work out, I can return unopned stuff back to partsexpress. I'll be out a little bit of money, but live and learn I guess. I'm still a newb. |
#10 | |
| Some Quad els57 questions! - Novice Questions! | Fanuc | Planars & Exotics | 13 | 5th December 2007 09:26 AM |
| PSU for QSC amp questions | rkc7 | Parts | 5 | 10th November 2005 05:18 PM |
| Last questions about this | Madmike2 | Multi-Way | 9 | 13th June 2005 11:12 PM |
| Questions, questions, from newb DIYer | Phatman91624 | Multi-Way | 41 | 3rd August 2002 02:52 AM |
| Page generated in 0.13496 seconds (83.58% PHP - 16.42% MySQL) with 10 queries |
