Old 17th August 2006, 10:32 PM   #1
Question Zen V8-like Preamp using Tubes
Would it be possible to build a preamp using a similar circuit to the Zen V8 Power JFET amp but use a tube instead of the JFET? I drew up a diagram of the proposed idea...
I would ideally like to use it to power 300-ohm headphones or as a preamp. I have a couple low voltage tubes (6GM8) that have a maximum plate voltage of 30V, which would seem to be right for this job. I am not too familar with the cascode amp concept, so I am probably missing something here. Would the MOSFET add any sort of current gain that would be useable for driving headphones?
Does this circuit look workable? I am not sure what to do yet for the resistor values that are missing... Any thoughts?
Old 18th August 2006, 07:25 AM   #2
MRupp is offline MRupp  Germany
MRupp's Avatar
Hmmm no, you would still need an aleph current source on top, replacing the biasing resistors, look at the ZEN V9 (installement 4) and ZEN V2 articles for details.
Martin Rupp
Building a preamp - somewhat new to tubes jscherer Tubes / Valves 3 19th February 2009 03:21 AM
Tubes as preamp.. Ryssen Car Audio 9 25th July 2006 05:34 PM
preamp tubes change mongiak Tubes / Valves 3 19th August 2005 05:44 PM
J-FET preamp/DI vs tubes qveda Solid State 2 30th December 2004 05:05 AM
What tubes are best for preamp? ronjg Tubes / Valves 7 31st May 2002 11:36 AM
Page generated in 0.07102 seconds (67.76% PHP - 32.24% MySQL) with 11 queries
