#31 |
Yes, that's right. But I have enough plugs, that's not the problem... my problems are bigger. Cost, dimension (placement), weight, WAF, skill for building the case (very hard I see), finding parts and maybe something else...
I think there's enough pain.... ![]() Cheers Giacomo |
#32 | |
Banned
I suggest using 2 or 3 toroids per channel, each 800W , about 56 Euro at Reichelt |
#33 | |
Giacomo |
#34 | |
hi, till i know how i can connect 2 torros, but how to connect three - where to pic up the middle ground when using three? kannst mir auch persönlich mailen, my english is not the best.... Ralf |
#35 | |
I calculated my X Soz for about 150 to 180 lbs -per channel! I think a aleph x should be as good or better, and way cheaper. Next time i start building my first aleph x. Ralf |
#36 |
An Aleph-X?
I don't know, do you think it's better? If a 50W XSOZ is too much for me, I would think about scaling down the output power, not changing amp. I haven't looked at Aleph-X yet, is it still no-feedback? I have to decide carefully, I thought that SOZ was the "cleanest" Pass Amp (simplest ecc. ecc.), with the only problems of little power and low damping factor... isn't it right? I know that there are several versions of Alephs too... I'll take a look on the thread. Cheers Giacomo |
#37 | |
ciao, Roberto Amato |
#38 |
Do not make a 50 watt SOZ or XSOZ. 20 watts is the most you should make. Beyond this it will not play much louder. It just makes lots of heat. And making a 20 watts SOZ is still fairly large to make.
Paul |
#39 |
...i think with your laura speakers a 10 watts xSoz wil be more than enough
Ralf |
#40 |
You're right Roberto, I know that I've got the right speakers for a SOZ. That's why I'd prefer it to an Aleph.
I'm seriously thinking about scaling down the power rating... Maybe 20 or 30 watts, as Gnomus said. I'd prefer something more than 10 watts, Ralf, so I'll be sure to avoid problems while listening to my favourite rock groups I don't think that 20 watts is impossible. As usual, thank you all for your kind attention. Giacomo |
| The end of the 300b Dream? | duderduderini | Tubes / Valves | 15 | 27th February 2008 05:58 AM |
| "....This is not a Dream.... | KBK | The Lounge | 20 | 27th February 2005 10:19 PM |
| DREAM-77 problems | muhy3 | Multi-Way | 0 | 2nd November 2004 01:15 AM |
| Dream Kit? | realtree71 | Multi-Way | 8 | 20th February 2002 06:30 AM |
| The Beast...dream to reality. | Sam | Solid State | 10 | 15th July 2001 10:44 PM |
| Page generated in 0.11013 seconds (78.40% PHP - 21.60% MySQL) with 11 queries |
