#21 |
Magura when soldered to a copper block like you used do you have any idea what the
thermal resistance case to sink will be. |
#22 | |
Before I used this method, one of my "test the limits" setups, would send the temp of the JFET up on the wrong side of 150C. With the copper block, it's below 100C, and (embarrassing, I know) limited by the capacity of the heat-sink. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#23 |
I have silver solder. Do I need anythink but the blank copper and a powerful solder iron???
#24 |
I just drilled and tapped two holes flanking the fet. Then cut a small length of aluminum and screwed it down with a silpad under the fet.
| Looking for 4pcs of LU1014D | gionag | Vendor's Bazaar | 0 | 9th September 2008 10:36 PM |
| FS: Lovoltech LU1014D | dhole | Swap Meet | 0 | 31st December 2006 10:35 AM |
| how much is the transconductance of lu1014d | john-china | Pass Labs | 6 | 14th July 2006 08:12 AM |
| Buy LU1014D | blackwolf1254 | Swap Meet | 5 | 16th March 2006 09:33 PM |
| what is the mounting depth and mounting diameter of this? | lemans23 | Multi-Way | 2 | 26th October 2005 10:52 PM |
