I have 2 CL30s. Can these be used instead of the CL60?
Thanks, Vince |
#2 |
No clue, huh.
#3 |
Formerly "jh6you". R.I.P.
I understand that CL60 has a cold resistance of 10 ohms while CL30 of 2.5 ohms. If two CL30s are applied in a series, the total cold R would be 5 Ohms, which I think useful for the inrush current control on the primary side of the transformer.
#4 |
Hi vdi_nenna
As you know, BOSOZ has a CL-60 from ground to the 3rd prong of the AC plug, not for current inrush on the xformer primary; so I don't think that the prior post is on-topic (though its the most common use of a CL-60) My non-expert opinion is that a CL-30 or two would be OK here. In fact you could just omit them and use a wire as many people do. I think I used one in my 1st version but not in my 2nd version....but I forget. On other threads this is a controversial saftey issue here at diyaudio.com. Think about it, if your chassis goes "live" do you want any built in resistance from the case to the 3rd prong ground? This is why a few of people say not to use anything from ground to 3rd prong but many others say its no big deal and helps with ground loops. Others even put in a 10-200 ohm resistor instead of a thermister. whoa. I've seen a discussion of this before but I think it would be tough to locate it with the search engine. Perhaps the "safe" thing to do would be to omit it and use a direct connection from gnd to 3rd prong, and see if you have any hummmmm. If you do try a CL-30 in series, if still there try the other one in series.
My DIY audio projects- PartTimeProjects.com. |
#5 | |
![]() Hmm . . . quite negative words. Of course . . . i could misunderstand the question . . . Anyhow, having the thermistor on the primary side of the bosoz is no harmful at all. I have it. Thanks to it, when I power on any one first of my pre or F1, I do not hear any "pop" noise. I am happy with the result. If you just argue that it is no need, it would be your choice. |
#6 | |
However, with all due respect, when someone asks about the cl-60 in the bosoz I take that to mean the cl-60 that appears in Nelson's bosoz schematic at the 3rd prong of the power connector.
#7 |
O, thanks, Lgreen. I feel shame on me.
#8 |
If one CL30 will work, I'll run with it. I was worried that there would be too little resistance to ground. In other words, if the CL30 heats up too fast and the resistance drops...what will happen?
Thanks for the help. Vince |
#9 |
As is supposed to happen, the fuse in the primary will do it's job.
Cyclotronguy |
#10 |
Normally a Thermistor is not needed for a preamp! So you can safely forget about it
Steen |
| BoSoZ PSU Question | Raoul | Pass Labs | 4 | 8th March 2005 02:44 PM |
| BOSOZ PSU question | Tyimo | Pass Labs | 11 | 2nd February 2005 06:41 PM |
| bosoz question... | cowanrg | Pass Labs | 9 | 27th November 2004 01:39 AM |
| BOSOZ with CCS, and a question | jh6you | Pass Labs | 11 | 26th March 2004 05:25 AM |
| BOSOZ question | audionut | Pass Labs | 1 | 27th July 2002 02:34 PM |
| Page generated in 0.09887 seconds (80.57% PHP - 19.43% MySQL) with 10 queries |
