Old 23rd October 2006, 09:29 PM   #51
Fuling is offline Fuling  Sweden
All amps need good power supplies:
Edit: The PSU consists of a 400VA 2x24V transformer, 4 x 10 000uF 40V caps and 2 x 25mH 3A (airgapped) double C-core chokes. The heatsink will hold two capacitance multipliers for further smoothing and slow startup.
Old 23rd October 2006, 09:31 PM   #52
One channel without cover:
Old 23rd October 2006, 09:32 PM   #53
Both channels operating late one night, the voltage reference LEDs shines a bit too bright for my taste:
Old 24th October 2006, 12:27 AM   #54
Paper mache horn fabricator
carpenter's Avatar
Default Nice looking project
tell me more about your power supply. It looks beautiful. I'm a believer in filtering chokes. I run an LCLC filter on my ZV7-T. It's dead quiet, even with 110db 1w1m horns.
John
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 24th October 2006, 07:39 AM   #55
Thanks!
I strongly believe in CLC och LCLC filtering whenever quiet power supplies are needed. I got a bunch of these chokes from a surplus store a couple of years ago and I think 25mH will be more than enough to make this amp completely silent.
After the CLC filter comes this IRFP260-based capacitance multiplier, I need to drop a few volts and, most important, have a slow startup to avoid damaging my speakers.
Old 24th November 2006, 09:04 PM   #56
I finally got some top plates on these babies:
Now when they are finished I realize that cascoding the output stage probably would improve things quite a bit (not that they donŽt sound marvellous as they are) but ripping them apart and changing the circuitry would be too much work.
ThereŽs also a risk of damaging the threadings by removing and reinserting the bolts too many times and i DON`T want that to happen (again...).
The PSU remains unfinished since IŽve been doing a lot of prototyping and started (and almost finished) a X-Soz project simultaneously.
Once the X-Soz gets finished IŽll hook everything up in an nice and hot biamped setup
Old 24th November 2006, 11:23 PM   #57
carpenter's Avatar
now there's a sexy pair
nice work, just in time for the holidays.
John
Old 25th November 2006, 06:12 AM   #58
Thanks!
Their big, balanced brother will also be finished soon I hope
Little brother of the XA-200 available? (XA-150) MEnsing Pass Labs 17 6th November 2002 05:37 PM
Page generated in 0.08504 seconds (77.49% PHP - 22.51% MySQL) with 11 queries
