Input selector configuration
Old 2nd August 2006, 12:39 PM   #11
pooge is offline pooge  United States
Originally posted by AndrewT
However if two sources or a source and an amp have both got audio ground connected to safety ground then isolation when deselected is not the issue. HUM, lots of it, when selected is the major issue.
There is a solution but I suspect the switch type is not readily available if at all.
The signal could be switched break before make and the ground could be switched make before break. That may give you what you need. A selector with the tracks specially made for this purpose could easily be manufactured. Similarly relays with delays could achieve the same.
I favor this approach. It's fairly easy to custom order a switch like this. Making the grounds before braking while switching may prevent pops and hum while switching. Also, if the input jacks have grounds isolated from the chassis, connect the input jack grounds to the chassis via a capacitor or capacitor resistor combination with leads as short as possible to prevent the "antenna effect".
Input selector configurationHide this!Advertise here!
Boz AP1.7 Input Selector PCB Stones Pass Labs 2 14th November 2006 06:08 AM
UCD input configuration Bgt Class D 20 11th October 2005 09:35 PM
Best Input differential configuration in amplifiers. Workhorse Solid State 85 17th September 2005 09:33 AM
Input Selector Semir Solid State 7 28th December 2004 06:18 AM
Input selector: need help Cobra2 Parts 1 8th March 2003 07:31 AM
