Old 28th July 2006, 03:52 PM   #1
Default power amp remote turn-on
Hello,
It seems that the large caps used in power supplies have a limited
lifetime and this problem is made worse by turning the amp on and
off each time it is used. Since I have Aleph 2s, leaving them on all the
time is not an option.
So, it seems there is the option of remote turn-on, whereby the amp
itself is not powered but the power supply is always energized.
I want to change the switch wiring and in parallel add a relay to do the
amp turn-on; the power supply would be energized whenever the
amps are plugged in. Of course I would retain the fuse as the primary
safety that can shut the whole thing down in case of problem.
I have a couple questions:
1) for an aleph 2, does one just power off the entire amp (ie everything
after the PS caps) with the
switch/relay, basically cutting all the amp from the PS? Or does one
just power off the output stage transistors - the voltage amp stays
powered up all the time.
2) is there a preferred relay for this purpose? I have 24V DC supply in
my preamp already so I would use 24V relays and wire the power amps
up to the preamp switch. I was looking at 8A relays but there are 20A
and 30A relays also and I prefer more overhead but want to have
high quality relays, I only need 2 so a couple extra dollars each does
not bother me.
3) Has anyone had bad experience with large turn-on/off pops
at the speakers as a result of this mod?
THanks for any replies!!!
Old 28th July 2006, 06:34 PM   #2
The one and only
Nelson Pass's Avatar
The concern about the reliability of the big electrolytics is
not worth sleepless nights.
Over 35 years my experience is that they take a lot of abuse
and heat and last 15 to 30 years. I make no effort to extend
the life of capacitors, and when they die of old age I stick new
ones in.
Old 28th July 2006, 11:50 PM   #3
Nelson -
Always a thrill to read your musings, even more so when it's an answer
to a question I posed !!!!
Thanks for the info.
Given this I may still do the remote turn-on one day, just for the
"coolness" factor !!! But I will probably wait longer now, I have other
things on the go.
Cheers!!!
W.
hifonics viii remote turn on issues.... marko Car Audio 2 26th February 2009 04:50 PM
denon head unit, no remote turn on? an2ny888 Car Audio 3 24th October 2008 08:56 AM
Remote turn-on for power amp jwb Solid State 13 10th March 2008 09:05 AM
Remote turn on on amp HailAngus Car Audio 2 2nd August 2005 09:40 PM
remote amplifier turn-on george a Parts 2 12th November 2002 12:15 AM
Page generated in 0.07904 seconds (73.50% PHP - 26.50% MySQL) with 10 queries
