I know that no the first and no the last thread about "zen4 PSU" and I apologize to create on more.
I designed 2 boards for the C-L-C filter from my Zen4 but I have a question: -What is the best choice between these 2 boards to have less noise around it? Why this question? Because on of this board would be under the Zenv4 board! I plan to use the following parts to build this board - Aerovox ALP22 10000uF 63v - Wima MKP10 4.7n - 2.2mH air-core inductor ( 0.60 ohm, 300W) ![]() ![]() I think that the 2nd solution is a litel better because caps are equally distributed on either side of the inductor. |
#2 |
The one and only
Depends on the ripple rating of the caps. Often, most of the
caps must be used in the first bank because the ripple current is high. Figure on a ripple current rating 4 times the DC draw of the circuit, and parallel enough caps to get that figure. The remainder can go after the inductor. |
#3 |
my zen v4 pair in test is running now with only one cap after the bridge, it's a 10.000uF / 63 V SIKOREL and I have absolutely no audible hum on my speakers. The SIKOREL run up to 125°C!
This cap has a ripple current of 30A at 100Hz at 85°C!, in comparison with normal caps which have between 5 and 10A. One sikorel in Germany is about 25€, the others between 5 and 10€. On the cap I have seen a ripple current of 2V peak to peak, stabilized I see 10mV - the same value as described in Zen Part3. My zen has no R1, means that it has about 2.6A current. |
#4 |
another one:
the temperature limit of the SIKOREL is 125°C, in my ZEN I have about 55°C |
#5 |
Don't really mean to thread jack here but I have a quick question wanted to ask for a long time. How do one measure the ripple voltage for a capacitor when the amp is running? Last time I tried, the prob of my MMeter also welded to the leg of the cap, when I set the dial of the meter to measure AC across the terminals of a cap. A real newbie question.
Regards, Chris |
#6 |
Hi Chris,
is it possible, that you tried to measure ac-current instead of ac-voltage? I have done the measurements on a scope. Peter |
#7 | |
The scope is definitely the nicest way to check ripple but a good True RMS meter would do the job likewise. Jens |
#8 |
Yes, stupid of me, I tried to read/learn from books and magazines, but they don't normally tell you practical things like these. Anyway thanks for all your answers, scope is the right tool then; enough for me here intruding.
Sorry PsykoK. Regards, Chris |
#9 | ||
Your question were good and interest me too . I check the datasheet from my caps and I found that : Quote:
An other solution ofr me is to use an other sort of caps from Vishay Roederstein :EYN07CB510J02 (10 000uF 63v) They have very interisting spec: ESR@120Hz : 0.035 ohm Z@10KHz : < 0.030 ohm Ir @120Hz, 85°: 5.3 A The Ir is mabe to slow? |
#10 |
the Roederstein CAPS are ok, but you will need two of them per channel.
the link for the epcos(siemens) SIKOREL is here: http://www.epcos.com/inf/20/30/db/alu_01/01090117.pdf |
| ZenV4 noise question | Deafboy | Pass Labs | 5 | 18th August 2004 04:22 PM |
| Balanced ZenV4 again | stani772577 | Pass Labs | 9 | 4th August 2004 11:03 PM |
| Another ZenV4 up and running | Zapped | Pass Labs | 30 | 4th December 2003 01:49 AM |
| My ZenV4 Monos | Orgonom | Pass Labs | 21 | 5th March 2003 05:02 PM |
| capacitors for my ZenV4 PSU | PsykoK | Pass Labs | 0 | 3rd December 2002 01:07 PM |
| Page generated in 0.10146 seconds (81.74% PHP - 18.26% MySQL) with 11 queries |
