#31 | |
I forgot to add an observation about Sikorel (but I think appliable to any other cap, especially big ones): they need a lot to "burn in". The sound "relax" a lot after many 10s hours. At first I thought was mosfet that needed so much time, but after having substituted the "burned in" ones (~400hrs) with a mint couple, the sound was very very close to what I was used to. That surprised me, without that try I would have never known. ciao, Roberto Amato |
#32 | |
#33 |
Is there no disadvantage using coils in the ps?
As far as i have seen, Nelson Pass doesn't need them in his amps. In his x-models he has NTCs in a CRC-combination. |
#34 | |
don't forget that the more cap you add, the more the ripple spectrum shifts to higher frequencies, where the rejection of the amp get worse. Indeed, it will for sure change the sound, but not necessarily for the better. If you are interested, his has been discussed in other threads ad nauseam Jan Didden |
#35 | |
#36 | |
#37 |
I am sure that we have all seen the pictures in the Aleph-X thread, but for those that haven't, here is a link to the pictures of the XA-200 and brief descriptions of each by Mr. Pass.
XA-200 pictures from Aleph-X thread. He has implemented RC filtering before, just look at the BOZ. Of course it is much easier to realize an RC filter when the current demands of a system are in the milliamp range. Speculating what the demands from the XA-200 power supply are, I can understand the use of the thermistors as part of the filter network for the power supply. Also, as Jan has said, filtration capacity, its impact on diode conduction angle, and its effects on noise spectra have been throughly explored, albeit don't let that stop a thoughtful and lucid discussion from continuing. Later,
-Todd |
| ZenV4 noise question | Deafboy | Pass Labs | 5 | 18th August 2004 04:22 PM |
| Balanced ZenV4 again | stani772577 | Pass Labs | 9 | 4th August 2004 11:03 PM |
| Another ZenV4 up and running | Zapped | Pass Labs | 30 | 4th December 2003 01:49 AM |
| My ZenV4 Monos | Orgonom | Pass Labs | 21 | 5th March 2003 05:02 PM |
| capacitors for my ZenV4 PSU | PsykoK | Pass Labs | 0 | 3rd December 2002 01:07 PM |
| Page generated in 0.10121 seconds (78.46% PHP - 21.54% MySQL) with 11 queries |
