Old 27th July 2006, 02:02 AM   #21
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
C3 (bias capacitor) changed from 220uF to 2200uF.
Upper and lower diode different position. Upper diode before base stopper 68R, lower diode after base stopper 68R.
Old 27th July 2006, 02:42 AM   #22
Formerly "jh6you". R.I.P.
Babowana's Avatar
The diodes look like two one-way bridges
from the output to the +/- of the cap. . .
Old 27th July 2006, 01:41 PM   #23
Question NPass answer re "bias & kill the turn on thump"
Image http://www.diyaudio.com/forums/attac...amp=1153941051 are worth a thousand words (for dummies like myself for sure). Thanks
Diode can be a a zener like 1N4148 ?
Old 27th July 2006, 01:51 PM   #24
Babowana's Avatar
Default Re: NPass answer re "bias & kill the turn on thump"
Zener? No, no, no!
Diode. IN4004 would work.
Old 27th July 2006, 06:43 PM   #25
The one and only
Nelson Pass's Avatar
Any diode will work.
Old 27th July 2006, 06:57 PM   #26
Default In rush limitation
So 1N4148 would be fine ?
(Sorry I'm not fluent enjough to understand the difference between a diode and a zener) I reckon Zener Is a Diode but there are diodes that are not zener. I was a bit suprise by the 1N4004 - seems oversized (maybe Babowana JH wanted to have a good time) Thanks anyway
Old 27th July 2006, 07:46 PM   #27
The one and only
a zener diode is just a diode with a low breakdown voltage.
In this case you could use some 5.6V zeners easily enough.
There are diodes you wouldn't use, like a 100 amp rectifier.
Old 28th July 2006, 01:01 AM   #28
Babowana's Avatar
Default Re: In rush limitation
I just wanted to have normal diodes as on the drawing, safely
avoiding my ignorance. I casually thought about 1N4004, which
I use most time.
Anyway, thanks to Nelson, you have full answer. . .
Old 28th July 2006, 06:25 AM   #29
Default DIode
Thanks to all for their contribution.
What could be the cause, now that the DC offset trimmed down by the R6 values is set to +1mv -1mv and the bias via R11 is set to 1.55A, after an 1.5 hours the amplifier start giving a hum, like a ground loop in the speaker.
Old 1st August 2006, 12:14 PM   #30
Question A40 amplifier - who could help ?
Hello,
In the early eighties a firend built an amplifier which he viewed as state of the art at that time for its schematic. Unfortunately he passed away and recently the amplifier did the same. I ended up opening the box and searching the web to find where / how this amplifier (which I like the sound very much) could be brought back to function. (ok this is almost pathetic..since i know little to nothing about electronic) Searching the web I found the passdiy and this forum sites which are full of all information I needed to get the amp fixed (almost). I'd like to thanks Mr Pass as well as all others who by their questions and answers have teached me a lot and fix the amp.
Beeing far far having a good understanding, one issue remained unsolved yet and even after several searches, I haven't found how to address it. Maybe some of you would have the answer, please be thanked again. Here it is :
There is some hum in the speaker.
I've removed the transformer away to no results.
I've applied Eric (http://www.facstaff.bucknell.edu/esa...ovies/a40.html) recommendations as well as Mr Pass (http://www.diyaudio.com/forums/showt...953#post969953) although there i haven't found 2200uf tantalum so far (car we use electrolitics instead ?) But to no avail.
Here are the measurements (if that helps)
Right channel
+DC 31.20; -DC 31.20
DC offset 2.8mv
Bias 1.56Amp per trail
Voltage drop
- D1 - D2 1,270V
- R7 0.642V
- R6 0.592V
- Q7 - Q9 emitter 1.089V
- R10 0.636V
- start up thump 0.184V
- light hum yes
Left channel
+DC 31.46; -DC 31.46
DC offset 0.1mv
Bias 1.64Amp
Voltage drop
- D1 - D2 1,286V
- R7 0.656V
- R6 0.589V
- Q7 - Q9 emitter 1.026V
- R10 0.649V
- start up thump 0.343V
- light hum yes
1°) What can be the cause of the hum in the speaker ?
2°) I don't understand why the difference in the start up thump.
The only difference I'm able to noticed with the schema on passdiy is the transformer. It is a secondary 1kVA at 24Volt DC with 8 wires 4 are connected to two rectifier of 50Amp 600V and the 4 other a fixed on the ground. I don't know if that makes a difference. Many thanks anyway.
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
Supressed bias amplifier, automatic variable bias system. destroyer X Solid State 2 20th September 2004 10:24 AM
Copyright ©1999-2013 diyAudio
