Zv9 as preamp? - Page 2 - diyAudio
Old 21st July 2006, 09:00 AM   #11
Err.... Who is Mr. Pass?
Seize the day
Old 21st July 2006, 09:08 AM   #12
Formerly "jh6you". R.I.P.
Babowana's Avatar
He looks like
Old 21st July 2006, 07:21 PM   #13
flg is offline flg  United States
flg's Avatar
Err...Who is Papa I think you may find something in the US Patent Office If your looking for "Pass"
I think you may score a few hits on any search engine
Not to forget, passdiy.com firstwatt.com and passlabs.com
And, you may find countless publications, highly praising his work...
You may even notice the title of this Forum Catagory
Without Mr. Pass... We would all be in the Solid State Forum??? Who is Mr. Solid State?
Old 21st July 2006, 11:32 PM   #14
Onvinyl's Avatar
that was exactly that kind of answer I hoped for: I tried, but something else seems to be better.
In quite a few MC-phono amps, we have a SE FET as first stage, sometimes cascoded, sometimes paralleled.
If we look at the ono's first stage, which is cascoded and is fed by a cap multiplier: is a aleph-style CCS beneficial or not? Might be worth to try...
thanks,
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 24th July 2006, 03:41 PM   #15
Stefano is offline Stefano  Italy
Default j-fet pre
Are you thinking to use lovoltec power fet for the pre?
Is it possible to replace the IRFP610 with a cascoded j-fet?
Let's make something special
Old 24th July 2006, 03:54 PM   #16
steenoe is offline steenoe  Denmark
steenoe's Avatar
I had the Toshiba devices in mind The BoZ and the BosoZ were tuned at getting the best from a Mosfet, in this case IRF610's. I doubt that a Lovoltech is a direct plugin replacement.
The BoZ and BosoZ with their high'ish railvoltages, are dedicated to get the best from a mosfet.
Steen
Old 24th July 2006, 06:29 PM   #17
Onvinyl's Avatar
Default Re: j-fet pre
No, I my first try would be the 2sk170, small signal low noise fet from toshiba, well known in this forum. A 2sk369 should work if you need gain.
Rüdiger
Old 24th July 2006, 08:34 PM   #18
nobody special's Avatar
I think the lovoltechs make their magic with low voltage and around 2 amps of current, so not likely a good candidate for a preamp unless you want to run it at power amp levels. The smaller jfets have less input capacitance too.
Steve
Old 24th July 2006, 09:01 PM   #19
MRupp is offline MRupp  Germany
MRupp's Avatar
Default Lovoltechs vs. other JFets
The Lovoltechs have a triode / resistive region up to around 4V and in the Zen V9 they are operated exactly in this region. Maybe this region is even higher at lower currents It might be still be a good idea to try a preamp with the Lovoltechs, and the low voltage isn’t an issue if you use them in a cascode circuit.
And there are countless preamp circuits around using SK170s so you would have to be very creative to come up with something that hasn’t been tried before.
Martin Rupp
Old 9th January 2008, 11:52 PM   #20
I'm bringing back this thread because I have a question that might have been raised (and answered) here, but I'm not sure.
Might the LU1014 serve well as the cascode device (replacing the mosfet) being controlled by a SK170 or the like? I'm thinking about this for a preamp (mc phono, to be precise) and not for the input stage which might be a transformer.
Might this be possible (does it have the, uh, guts)? Would it provide any benefit over the mosfet?
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 10:13 PM
Copyright ©1999-2017 diyAudio
