Old 5th December 2002, 09:38 PM   #1
DJG is offline DJG
Question My Aleph 5 isn't working
Hello!
I have made a testing PCB for my Aleph 5. I have completed the soldering and connected the wires.
The problem is, that when I increase the input signal, it starts clicking in the 6.5Ohm speaker. Control LED also starts to blink and PSU drops from +/-31V to +/-27V. It's almost like it would go into clipping.
I have 31V-0V-31V PSU with 2x47000uF/elco and 4.7uF/bipolar.
When the load is 8Ohm speaker the critical point is a bit higher, but when the load is 8Ohm 2-way speaker it's a bit lower.
It looks like it would start short-circuiting.
Does anyone have any measurments that are critical and I could made them as well?
best regards,
DJG
Old 5th December 2002, 09:44 PM   #2
MikeW is offline MikeW  United States
MikeW's Avatar
Diconnect your speaker. Check your DC ofsett at he output. It should be a few miilivolts. Then go to your shematic and check to see if you have the proper voltage drops. Both of the problems I had with my Aleph 5 were from blown up transistors Q1,Q2, or Q5.
MikeW
Old 5th December 2002, 09:50 PM   #3
DJG is offline DJG
Hello, MikeW!
Could you send me your schematic, because I don't have one with voltage drops on it. Please.
thx,
DJG
Old 5th December 2002, 09:54 PM   #4
MikeW's Avatar
Go to the Pass Labs homepage. They have the Aleph service manuals that you can download.
MikeW
Old 5th December 2002, 09:58 PM   #5
DJG is offline DJG
OK, thank you. I will get on it right away.
In case of any possible solution, please report them here.
I will report about the measurment results.
Best regards,
DJG
Old 5th December 2002, 10:23 PM   #6
DJG is offline DJG
All the measurments are OK - except the voltage on 1Ohm/3W output resistors. In service manual is written 4-5V, but I have only 0.22V and 0.27V. DC offset is OK - aprox. 60-70mV.
Any thoughts?
DJG
Old 5th December 2002, 10:59 PM   #7
You don't have to have 4-5 volts across that resistor! The Collector-Emitter voltage has of Q4 has to be 4-5V. If you take a closer look, you will see, that the voltage must be .5V. And that is fair for 0.5 amps/mosfet pair. Take a look at the upper mosfet's source resistor's voltage. If it is the same low value, then maybe the current source is not working correctly.
Try looking at the transistor's base-emitter voltage. It has to be close to 0.6V.
Miki.
Ps. I don't have experience with Aleph5, so maybe I am wrong.....
Old 5th December 2002, 11:36 PM   #8
The one and only
Nelson Pass's Avatar
What 10 ohm resistor?
Old 5th December 2002, 11:44 PM   #9
trigon's Avatar
I think he is reffering to 1 Ohm resistor not 10 Ohm, it is because of the no-space and big O ;-) 1Ohm
Trigon.
Old 6th December 2002, 12:53 AM   #10
grataku is offline grataku  United States
For someone that would signal the time to get reading glasses.
Mybe it was an oppttttiiiicccaal illusion.
Aleph ONO working - belated thanks to pquadrat GaryB Pass Labs 96 14th October 2009 07:44 PM
Aleph mini one channel not working yoke Pass Labs 7 9th March 2008 12:15 PM
One Aleph-X working, One to go wuffwaff Pass Labs 102 5th August 2005 07:36 AM
My Aleph-p isn't working PatPet Pass Labs 11 24th August 2004 12:04 PM
Aleph 2 Working!! Mark A. Gulbrandsen Pass Labs 14 17th December 2002 02:56 PM
Page generated in 0.09346 seconds (80.73% PHP - 19.27% MySQL) with 10 queries
