citation 12 mos fet
citation 12 mos fet
Old 24th April 2013, 12:32 AM   #81
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
Can you post and share your pcb layout and updated schematics with the ccs you used. I planning to build another one since i have plenty of power mosfet to use...
Old 16th May 2013, 08:49 PM   #82
Tazzz is offline Tazzz
Did some THD measurements on the amplifier. Measurements were done with a juli@ soundcard the amplifier was loaded with 8ohms and a uni-t 61E was used to ascertain voltage levels.
Sorry no 60W measure as i ran out of attenuation range.
Old 16th August 2013, 05:43 PM   #83
marc brown is offline marc brown  United States
marc brown's Avatar
Ditto on the schematics and pcb layout. Do you have any boards left? Maybe there's enough interest for a group buy of boards and/or components?
Old 20th April 2016, 03:02 PM   #84
marc brown's Avatar
Originally Posted by Tazzz View Post
I strongly advice Replacing R1 with a current source for the input diff pair.
Its obvious now when you look at the schematic that the input diff pair cannot control the VAS when the voltage across R1 is less then half the supply voltage, due the resistive load R2 (sized to split the current equally in the diff pair at normal operation)
Simply put when the supply voltage bellow about half the supply voltage Q3 is turned off and R3 and R4 acts as pull up on the Q6 putting what is left in the reservoir caps across the speakers...
I'm sourcing transistors for my boards. Is there a recommended Hfe range to specify when purchasing the 2SA970's? How tightly should I request matching of each pair?
Old 20th April 2016, 05:53 PM   #85
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
citation 12 mos fet
They don't require much in the way of matching.
That doesn't keep people from going for tight matches anyway...
Old 20th April 2016, 06:09 PM   #86
marc brown's Avatar
Old 29th June 2016, 11:11 AM   #87
kramskee is offline kramskee  South Africa
Hi guys,
I was just reading this thread. just to let you know ...... one of my local suppliers here sells an IRFPC40 ............. these are rated 600v, 6.8A and an RDS on of 1.2 ohms with much the same gate capacitance as the IRF240's............. I don't know if they're still in production and available on your sides of the world but they work fine and they're about half the price of the IRF240's ............. a little under rated current wise I know but if you're not planning on pushing 100's of watts of power they work just great!
IRFPC40 - FET N-C TO247 600V 6A8 1E2
this is a great amp! ................... Thank you Nelson
Old 29th June 2016, 05:16 PM   #88
The one and only
citation 12 mos fet
They would appear to be perfectly fine.
Old 30th June 2016, 07:40 AM   #89
cucuclock is offline cucuclock  France
citation 12 mos fet
Hi everybody,
I'm building a C12 with the Tazzz pcb, and I'm wondering, is the input impedance really 10K?
I have 2 option a this point, the B1 buffer, and it seems is 1k output impedance or VTC, which lower the output impedance for levels less than 0 bB, ex. half the volume is 1/4 the impedance, with a quite low output impedance dac 2v output. Any of you can give me some advise, confirmation, suggestion? I will appreciate.
Is a 500W transformer could be enough for the C12, I wont be too far with the Bias, I promise.
Old 4th August 2016, 05:42 PM   #90
schubert is offline schubert  United States
schubert's Avatar
Default Citation 12 rebuild
Due to the generosity of a friend I recently was offered two non-functioning Citation 12s (thanks Dutch), and after looking them up and finding Nelson's mosfet mod article I gladly took them. I used Tazzz's schematic for the complementary version, which had more up-to-date parts than Nelson's original, and decided to do one with IRFP240/9240 and the other with laterals (BUZ901/906).
I was unable to obtain boards from Tazzz so I had to fit the circuit on the old board, which was complicated by the fact that the diagrams of the circuit board in Nelson's article aren't very readable and aren't for the complementary version anyway, so I made my own based on the board diagram in the service manual. It's a little busy looking but may be of some use to someone else who wants to try this project.
The 240/9240 version went together like a dream and worked perfectly right off. I used Mundorf 10,000uF 4-pole caps in the power supply (I always wanted to try the Jensens but they were too expensive) and 0.10 ohm source resistors, as I couldn't find Tazzz's prescribed 0.01 ohm versions. I didn't do Nelson's prescribed biasing procedure with the oscilloscope but rather just jacked up the bias over time until the heat sinks got up to my target temperature, about 47, which ended up being around 200mA. Initially the sound was unimpressive (I was coming from an M2) but after a change of preamps and some run-in it sounded really nice. It's not an M2 or F6 - a little aggressive in the upper midrange (strings), but it has better bass (well, more bass anyway) and more grace under pressure than either.
The lateral version was a challenge, and a great learning experience for me, a relative newbie to the secrets of the inner workings of power amps. First lesson - you can't just drop laterals into a circuit designed for vertical mosfets! You get the positive power rail voltage at the output! Yikes! (I did have the pins all connected correctly, buy the way.) After reading and re-reading all the Citation 12 threads here I picked up enough hints to figure out that I needed to change R14 to accommodate the BUZ's lower turn-on voltage. After much experimentation and a few burned gate resistors (the bias circuit tends to oscillate pretty severely at around 100Hz or so if the resistors aren't right) I found that 470 ohms for R14 (Vbe multiplier resistor), 570 ohms for R18, and 680 ohms for R19 work well. Oscillation occurs if the bias is too high and the gate resistor values too low. If R14 is too low you can't get the bias high enough - with 220 ohms I could only get it to 47mA or so. I suppose R14 could be as high as 2K - I was at 470 when I got it to work so I just left it there. These values may or may not work for you but they will at least give you a place to start. I also tried 220pF capacitors from gate to source as Rod Elliott does in his P101 (makes up the difference in capacitance between the NPN and PNP laterals) - don't do it! They made the circuit oscillate like crazy every time I tried them. In the end I settled for around 250mA bias, which gave a heat sink temperature of about 50-52 at idle, and around 54-55 with the cover on after being played for 1-2 hours.
Sound-wise, the lateral version is more even and preferable to the vertical mosfet version. Still not an M2 or F6, but mighty fine. I finished both off by re-doing the case finish - they were both pretty rusty when I got them. Some before/after pics are below, along with the board diagram. The board pics and diagram were too big to show up here so I just linked to them.
Board diagram
Front of board
Back of board
citation 12 mos fetHide this!Advertise here!
citation 7.1 mr l Solid State 30 24th September 2011 01:41 AM
Citation II OPT? Sherman Tubes / Valves 17 13th December 2006 06:48 AM
HK Citation II DJH Swap Meet 2 5th January 2005 07:17 PM
H/k Citation 7.0 xpablo Digital Source 0 30th December 2004 08:33 AM
Citation 13? vacuumhead Solid State 3 4th September 2004 04:54 PM
