citation 12 mos fet
citation 12 mos fet
Old 6th September 2007, 04:06 PM   #61
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
citation 12 mos fet
That is the job of R12. I don't think the diode will add much.
Old 6th September 2007, 04:50 PM   #62
gaetan8888 is offline gaetan8888  Canada
Hello
So that diode won't do much but won't do worse ?
Btw, did you do any update to that project since ?
Thank m. Pass
Gaetan
Old 20th November 2007, 05:35 AM   #63
posxia is offline posxia  China
My dear DIY brothers:
I did citation 12 mos fet last week too,the sound quite good .each channel is handed with 2 IRFP240, but till now there are two
problems troubling me.
Firstly, when the voltage is large (eg: V=+-45V I=100mA), the IRFP240 is very easy destroyed.
Secondly, when the current is large (eg: V=+-35V I=1A), the IRFP240 is very easy destroyed too.
But it can work very good when the voltage is +-35V and the current is 100mA.
I had noticed the turn-on thump of C12, but is this the reason who destroyed the IRFP240?
Who can give me a favor about the explanation of this case.
Thank a lot!
Old 21st November 2007, 01:42 AM   #64
The one and only
citation 12 mos fet
The voltage isn't too high for the devices, but perhaps your
bias is running high, and possibly you are seeing oscillation.
Can you monitor the bias currents?
Old 8th January 2013, 06:29 PM   #65
camargo is offline camargo
FHigh Quality IRFP240 Push Pull Audio Power Amplifier Kit Based on Citation 12 | eBayriends,
I bought a plate amp citaion 12 on Ebay, the seller is not sure about it. I wonder if the transistor Q4 should be glued to the heatsink for thermal control? The scheme at the end of this page
Already many thanks for the information
Old 10th January 2013, 04:23 AM   #66
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
I also made this amp before and still working right now...before q4 was on the board, it works but easily damage the mosfets ,so i pulled them up and screwed on the main heatsink and avoided the problem... this serves as thermal track transistor..
Old 10th January 2013, 10:10 AM   #67
Very good Junm, grateful for the advice! It is a BC546B. I'll turn it heat to the heatsink and try your sound. What did you think of the sound? It is well detailed? Congratulations .....
Old 14th January 2013, 08:50 AM   #68
Junm's Avatar
I used different transistors and power mosfets from hitachi...for me, sound is nice and has brilliant HF.
Old 14th January 2013, 09:53 AM   #69
I made the connection heatsink, the circuit seems to be very stable. Did coupling audio with tantalum capacitors (10uf x 35v). The equipamantos MARANTZ NAD and have many of these capacitors in the signal line (audio), I confess, it was wonderful, if you want to try ....
Old 14th March 2013, 07:16 PM   #70
nrg2009 is offline nrg2009  United States
Would you mind posting a photo of the completed amp? I always worry buying a board of eBay, there may be mistakes in the board..
citation 12 mos fetHide this!Advertise here!
citation 7.1 mr l Solid State 30 24th September 2011 01:41 AM
Citation II OPT? Sherman Tubes / Valves 17 13th December 2006 06:48 AM
HK Citation II DJH Swap Meet 2 5th January 2005 07:17 PM
H/k Citation 7.0 xpablo Digital Source 0 30th December 2004 08:33 AM
Citation 13? vacuumhead Solid State 3 4th September 2004 04:54 PM
