Aleph-X with common-mode oscillation
Old 16th July 2006, 07:42 AM   #11
DACMan1 is offline DACMan1  South Africa
Ones I have is 15.5degC/W which means a temp rise of 52degC but its the best that will fit. However, forward voltage drop on these will only be less than 1V(worst case 1.15V and will drop at higher temperatures. Thus:
2.25*1=2.25W
2.25W*15.5degC/W=35degC
Worst case:
2.25*1.15*15.5 = 40degC
This is acceptable to me.
PS, they will be mounted directly on the heatsink, so lets say a 0.8degC/W case to heatsink junction temp. They have 1.6degC/W junction to case drop.
So the die will run at: (above ambient in case)
(1.6+0.8+15.5)*2.25=40.25degC
*1.15(worstcase) = 46.3degC
at worst case internal temp = main heatsink temp
gives realitic to worst case ratings of die temp 90-110degC.
These diodes will live quite happily at a die temp of 100degC.
Hopefully internal temp will be a bit lower
Old 16th July 2006, 02:47 PM   #12
Default absolute dc mode offset
I cant seem to find this in the main thread, the absolute dc offset of my amp starts at around 10V when cold and then goes down to -1V after about an hour. Is this normal?
Aleph-X with common-mode oscillationHide this!Advertise here!
Common-mode choke discussion please stellavox Power Supplies 8 25th July 2009 12:00 AM
common-mode chokes jarthel Tubes / Valves 6 11th February 2008 03:31 PM
Common-mode EI PS Chokes rdf Tubes / Valves 14 17th June 2007 08:36 AM
common mode questions zahlm Parts 1 24th May 2004 08:38 PM
Common mode chokes Dr.H Digital Source 1 24th July 2002 04:47 PM
