Old 14th July 2006, 01:45 AM   #1
XELB is offline XELB  Portugal
Cool supersymmetry, physical theory ?
Hey guys.
This is a little off topic but it's curious
http://en.wikipedia.org/wiki/Supersymmetry
In particle physics, supersymmetry (often abbreviated SUSY) is a physical theory which proposes a physical symmetry between bosons and fermions (also called supersymmetry). In supersymmetric theories, every fundamental fermion has a bosonic superpartner and vice versa. Assumption of supersymmetry mitigates and explains several problems in the Standard Model of particle physics; it also introduces complications of its own.
Supersymmetry was orginally developed in the 1970s by the research group of Jonathan I. Segal at MIT; at the same time Daniel Laufferty at Tufts University proposed a similar idea. It was also independently discovered by Soviet theorists Gol'fand and Likhtman. Although it first arose in the context of string theory, the mathematical structure of supersymmetry has subsequently been applied successfully to other areas of physics ranging from quantum mechanics to classical statistical physics. It remains a vital part of many proposed theories of physics.
As of 2006 there is no direct experimental evidence that supersymmetry exists in the real world. However, there is some indirect evidence which suggests that supersymmetry may be found at energies not too far above those accessible by today's particle accelerators. By the year 2007 the Large Hadron Collider at CERN should be ready for use, producing high-energy particle collisions that may be sufficient to reveal superpartner particles.
They also call it SUSY
My question is, Nelson Pass knows this similarity ?
Both use the same name.... I think we can call it a supersymmetry similarity!
SUSYS here's an ideia for a next amp technology hehehehehe
Chears
If you want power you must add control
Old 14th July 2006, 02:11 AM   #2
Blues is offline Blues  United States
Lightning In A Bottle
Blues's Avatar
"As of 2006 there is no direct experimental evidence that supersymmetry exists in the real world. However, there is some indirect evidence which suggests that supersymmetry may be found at energies not too far above those accessible by today's particle accelerators. By the year 2007 the Large Hadron Collider at CERN should be ready for use, producing high-energy particle collisions that may be sufficient to reveal superpartner particles."
We in audio know for a long time now that real working examples of SuSy come from PassLabs
NP has a degree in Physics from UCalifornia Davis, I've read somewhere here.
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
Old 14th July 2006, 05:46 AM   #3
CheffDeGaar's Avatar
Obviously he does Last sentence of the header of the SuSy article at http://www.passlabs.com/articles.htm
Cheers
/Cheff - Falling feels like flying, until you hit the ground
LP Physical Standards ? valveitude Analogue Source 24 14th November 2005 09:41 PM
physical CD tweaks? gigatron Everything Else 12 20th October 2003 01:19 AM
Physical Questions Jeremy Multi-Way 1 13th January 2002 05:40 PM
Page generated in 0.07719 seconds (72.14% PHP - 27.86% MySQL) with 10 queries
