#21 |
the magic R shouldnŽt be to low (>4k7). Startup voltage of around 5-10V is normal, going down fairly quick. You can do a few more things wich are explained in another thread to raise the magic R for better sound quality without changing the startup voltage. William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#22 |
Hi William, can you explain a little more about the magic R?
Which one is it? Right now I'm still getting a fairly high absolute DC offset. the pot is turn all the way down. Thierry |
#23 |
there are ae few magic RŽs: R46/47 (original HIfizen schematic) 4k7 Output to ground resistors (30-100 Ohms) Lowering R46/47 and to lesser effect the output to ground resistors will meke the absolute dc offset lower and more closely controlled. The disadvantage is that going below 4k7 for R46/47 will slowly worsen the sound quality and lowering the output to ground resistors will waste quite some power wich could go to the speakers. I tried some different configurations (different current sources, zeners thermal coupling etc.) and described them in a thread wich I will try to find and post. William
#24 |
http://www.diyaudio.com/forums/showt...975#post856975
here it is, and one more: Aleph X - rootcause of absolute DC offset drift hope this helps William
#25 |
Formerly "jh6you". R.I.P.
Thanks, William, for the kind details.
#26 |
Hello everyone,
winter is coming soon here but the good news is that now I have more time to work on my stuff. I've powered up my aleph-x for the first time since a few months to play around with my DC offset problem. I notice something wierd, if I short the input to adjust the offset I get a descent level of DC. But when I try it without shorting or with something feeding the input I'm getting around 3V between binding post cold and about 1.5V after an hour. Is that a normal behaviour to get such a difference short input versus not short? Thierry |
#27 |
do you use input capacitors? If not this could be the cause. William
#28 |
I tried with and without capacitor. Not much difference.
#29 |
you will need two capacitors of the same size to connect plus in and minus in. If using it unbalanced youŽll have to connect minus in via the capacitor to ground. William
#30 | |
What would be the right capacitor value to use? And what type? |
| BOZ bias adjustment help | rtate | Pass Labs | 16 | 11th July 2008 07:04 PM |
| Bias Adjustment Question | dakotadave | Tubes / Valves | 0 | 9th July 2006 11:05 PM |
| KT88 Bias Adjustment | batinal | Tubes / Valves | 7 | 20th May 2006 05:16 AM |
| Bias adjustment for Krell KSA 100 | Alex helge | Solid State | 9 | 26th August 2003 01:41 PM |
| Aleph 5 DC offset and bias adjustment | Bertie | Pass Labs | 3 | 22nd December 2002 02:49 PM |
