AlephX PSU- need help
Old 6th July 2006, 02:24 AM   #1
bach2800 is offline bach2800  Canada
Send a message via MSN to bach2800
Default AlephX PSU- need help
I'm building an alexh-x but a problem appear when at the initial testing of the PSU with no load on it. It keep blowing fuse.
I'm using a crc filter with 2 bridge, 56000uF - .25R - 56000uF. The fuse I'm using is 8A slow blow. something like this: http://s37.photobucket.com/albums/e9...nt=LOIC_PS.jpg
The transfo is from ebay, initially 240V input, 4x 38V output rated at 3700VA. I'm running it at 120V and get about 19V per secondary.Let me know if you think you need some more info.
Thanks for your help
Thierry
Old 6th July 2006, 03:52 AM   #2
metalman is offline metalman  Canada
metalman's Avatar
Are you using the NTC shown in the figure you referenced? If not, the initial current draw to charge the capacitors will easily blow the fuse.
Second, have you tried starting the power supply up slowly using a variac? That will give you some clues as to where the mistake might be.
Lastly, a good high wattage power resistor doesn't cost much and will provide a decent load to the power supply for testing purposes.
A few points to try and if they don't work out, we'll try some others.
Cheers, Terry
Old 6th July 2006, 04:16 AM   #3
I'm using 2 cl-60 one on the hot and one on the neutral
Could it be possible that 8amp fuse is not enough?
I didn't try with a variac but I'll get one tomorrow.
As for the load I have a 33R around 50-100W, would it be good for that purpose? I was not using one so far because I don't want to add more inrush til it work.
Thierry
Old 6th July 2006, 08:05 AM   #4
jh6you is offline jh6you
Account Disabled
If it is 3700VA at 120V main, the current handling is about 30A on the main side. In addition, there will be very high inrush current. Probably, there should be fuses on the secondary side too. Ayo . . . have no idea how to estimate the fuse size in this case . . . Nevertheless, the 8A slow blow is considered too small.
Old 6th July 2006, 01:21 PM   #5
TS Lo is offline TS Lo  Hong Kong
In this case - the transformer can only handle about 1800VA since the
copper wire used in the primary winding is only enough for (3700/240)
15 amp.
TS
Old 6th July 2006, 03:26 PM   #6
kropf is offline kropf
In the absence of a variac, try a light bulb in series with the transformer primaries. This will keep the fuse from blowing and let you look around to see if everything else is working fine.
Jeremy
Old 6th July 2006, 09:53 PM   #7
Problem solve, I happen to had a short capacitor who was pulling the juice. The variac was very handy in troubleshooting it.
Thank you all for your reply
Thierry
AlephX PSU- need helpHide this!Advertise here!
AlephX with 610? ijomojo Pass Labs 3 1st September 2005 04:45 PM
Best 1st amp:AlephX, 5 or a Zen? rif Pass Labs 7 15th April 2004 04:56 PM
ApexJr AlephX? tiroth Pass Labs 5 8th February 2004 12:58 AM
alephx dc offset lumanauw Pass Labs 10 24th December 2003 09:15 AM
IRF 230 or IRFP 140, what's better for AlephX ? Peter Daniel Pass Labs 29 26th September 2002 03:05 AM
Copyright ©1999-2017 diyAudio
