IRFP044 Paired in 8 fets, all the way from Germany!
Thanks for one of the user in diyaudio. |
#2 |
Capacitors are from RS
#3 |
BHC 47000 uF 25V X 8
#4 |
Paired Fets
#5 |
The Progress.
#6 |
Progress 1 Another angle of those gigantic heatsinks
#7 |
Glad to see you making progress.
Patrick |
#8 |
I am sorry that i didn't contact you for so long, as i havn't done anything to those fets, now i have mount them onto the heatsinks and make sure them they are all insulated.
The next step is to connect them up to the board. Angus |
#9 |
Banned
Take you'r time It will pay off
#10 |
I assume you use thermal grease.
Do you have mica insulation in between (I would recommend) ? Use the thermal grease sparringly. You should only smear on a thin layer uniformly on both sides of the mica with your finger. The grease is actually not very thermal conductive compared with metal, as it contains silicone grease and aluminium oxide particles. So you only need just enough to bridge any uneven gaps. The mica will do the insulation for you. If you have a laboratory supply, set the voltage to your working voltage (per FET) and current limit to just over your bias current. Use a separate 9V battery with a 1k trimpot to set bias across gate and source resistor (starting from less than 3V and increasing slowly to something like 4V). After it is operating at the right voltage and current for say 5 minutes, measure the temperature at the heatsink and at the transistor METAL case. The difference should not be more than 8 degC. Then you know your thermal grease is not excessive. Of course check the insulation first between transistor & heatsink with a multimeter. Many multimeters also have temperature measurement (thermocouple) capabilities. Patrick |
| 'LGT' Construction Diary | ShinOBIWAN | Multi-Way | 1793 | 5th January 2012 05:29 AM |
| HELP! Aleph 5 For Beginners. Step by step | obregoru | Pass Labs | 15 | 18th July 2003 01:29 PM |
| Page generated in 0.09880 seconds (82.23% PHP - 17.77% MySQL) with 11 queries |
