Old 17th January 2003, 08:01 AM   #21
Send a message via MSN to Tazzy
This is wat I'm going to use:
The inductors are 1,4mm if I'm not mistaken.
I'm switching over to a tube hybrid designed by Kristjian.
I'll be updating my Zen website I made today.
Kristjian's website could be a good source for some extra information, but most of the info is on www.passdiy.com
Old 17th January 2003, 09:03 AM   #22
miguel2 is offline miguel2  Portugal
In my ZenV4 I just have a single 20000uF electrolytic and then it goes directly to regulation. I am using 53V on the unregulated, after rectification. With this setup the amp is dead quiet, no hum at all.
Old 17th January 2003, 04:36 PM   #23
Ok!
Somebody tell me that it is good to but a 0,1uF capasitor on each diode of the bridge!
If I do that, I don't have to put the 1uF/MKP at the enter and at the output of the power supplie?
Old 17th January 2003, 06:08 PM   #24
Philo is offline Philo  United States
Arold,
The caps you are talking about are called snubber caps. They "buffer" sharp current swings going through the bridge rectifier, like when you turn the amp on. They also provide some quieting to the rectifiers which can be noisy. IMO, they are optional when dealing with amps less 50 watts as there are smaller swings and less filter capacitance. You can save a few bucks and just use the 1uF mylar caps shown in Tazzy's diagram. Many people say that you get more high freq detail when you use multiple electrolytic caps (4 or more) in a "bank" for filter capacitance. I do heartily recommend a poly or mylar 1uf cap after the electrolytics (also shown in the diagram). This will smooth out the sound of your amp. Especially if you use lower quality electrolytics for your filtering.
Philip
"If you didn't make it with your own two hands, its not really yours".
Old 17th January 2003, 10:46 PM   #25
Where can I find a poly or mylar 1uF capasitor on the digikey catalogue! I tried to find without succes????
Old 17th January 2003, 11:27 PM   #26
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
EF1105-ND is the part # for 1uf
Panasonic Miniaturized Metallized Polyester Film Capacitors
the 10uf part is used in the Zen V4
just look at the parts list
that's on the passdiy.com page.
of course you can also check out
www.partsconnexion.com/
for other examples
Old 18th January 2003, 12:14 AM   #27
It is good for the output capasitor but on the plan of the Zen V4 power supply, I see a 0,1 uF capasitor on the AV voltage, what I do with that ???
Old 18th January 2003, 01:10 AM   #28
moe29's Avatar
it's a filter capacitor placed across the line to reduce noise.
it should be a high voltage AC line rated cap.
Old 18th January 2003, 02:53 AM   #29
The cap doesn't have to be AC rated just high enough DC rated. The rule of thumb passed around here on the forum has been at least twice the voltage it will see, ie 120VAC choose a 250VDC rated cap or higher. Most people use 400VDC or 600VDC before the primaries and 250VDC after. Try to keep it in reason as this keeps your cost down and saves valuable space.
Philip
Old 18th January 2003, 05:34 PM   #30
At the primarie, I put a 1uF or a 0,1uF capasitor ???
On the shema bellow, it is a 1uF and on the shema of the Zen V4, it is 0,1uF???
power supplie for home amp j_dunavin Power Supplies 4 18th October 2006 07:17 AM
Between ZEN4 and ALEPH30 Skorpio Pass Labs 3 11th November 2005 06:31 PM
PC power supply for ZEN4 Anorgan Pass Labs 2 5th February 2004 01:08 PM
Pics of Zen4 Buhl Pass Labs 6 3rd November 2003 11:33 PM
Digital amplifier power supplie flanker20 Digital Source 3 7th January 2002 02:38 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
