hiMr. Nelson,Wuf Waf, Grey, GL and others
I have a question regarding aleph x improoving - there is a resistor from diferential pair to output. usualy 2.2kohm on kristijan schematic, 10kohm on gl and I do not see it on Gray schematic. whren I mooved from 2.2kohm to 10kohm-strange thing happen- sound improoved a litle bit-it sounds more analogue. however abolute dc ofset from 1V or so went to 6V ! I would like to ask how to vary absolute dc ofset? with pots I can vary it but not much also when I am adjuting I get that voltage across source resistors lifts to a 0.60-0.66V firs thing0 replaced 33ohm resitor to ground from output with 100ohm. - has no influence. I find folowing- "" There are two types of offset with the Aleph-X to consider. Absolute Offset: The voltage difference between an output terminal and ground. Relative Offset: The voltage difference between the the positive and negative output terminals. The absolute offset will affect your amplifier performance near it's maximum output, as the offset will cause the amplifier to start clipping at lower levels than can be achieved with proper adjustment. The good news is that the absolute offset can be set by adjusting the current in the CCS for the differential input transistors (the IRF9610's). Measuring it is easy using a multimeter, leave the amplifier on but with no input signal, connect the common probe to ground, the test probe to an output terminal, and read the voltage. how to adjust current in the ccs for diferential input? I run 24 mosfet .channlel, 12A bias. , 22.5V rails """o
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!.. |
#2 |
anyone?
#3 |
The one and only
For differential offset, you adjust the loading resistors coming
off the Drains of the input diff pair, and by this I mean you vary one of them versus the other. Generally I use a pot of much higher value than the resistors and put the wiper to v- and each leg to a resistor. |
#4 |
thanks Mr. Nelson, this is 2.2kohm resitors in my atached shematic?
if yes I am surprised because variuos aleph version has very diferent values(in Grolins version I can se it at all) for example one diyers easily variies from 4 to 10kohm. when I went from 2.2khz to 10kh I get 6V absolute ofset. is it normal? as I one of the forum member said theese resistors are evils and adviced to keep them as high as posible.. If I have good realitive and absolute dc ofset does it means my aleph x works great and sounds great? I do not have osciloscope. if theese two values are main I can stay tune with them slightly varying ather values/desired bias,output devices number.. just for records last month I killed 48 irfp240 mached mosfets.. and more or less source resistors. expensive hobby..
#5 |
The one and only
It is my experience that the resistors providing common mode
feedback (the 2.2K to which you refer) have values which must be optimize for any given version of the design. To determine the optimal values, you must perform a series of tests; absolute offset stability, CMRR, distortion vs amplitude and frequency, and of course listening. Lower resistance gives greater common mode feedback and so it gives the greatest absolute DC stability, but it is not also an absolute that lower values degrade the performance, as I have occasionally observed better performance at lower values. When we put a version of the circuit into production we test over a range of values as a matter of procedure. In general however, I recommend higher values, CCS adjustment, thermal compensation, and resistive loading of the output to ground. The goal is to minimize the absolute DC (the output referenced to ground) and the standard is a few hundred millivolts or better. |
#6 |
seems I have only one method from what you mentioned- my ears. when lower value I generaly liked sound better but also with this mod and increasing resistors from output to ground up to 100ohm I noticed somewhat limited power handling. abslolute ofset was 6V amp started clip much more earlier and it from listening it has some aded discortion. but it was very easy acceptable. I will try to play this way- to asemble few boards with all parts mached as well as posible 1%resistor 0.6w , 2x 1% 10w resisitors , 0,01V mached transitors. hope this will help to stabilize amp.
by the way Mr. Nelson You was wright- the bass of aleph x is much more better than aleph5. just few weeks needed to burn in new caps I think. with high quality bass drivers in wright enclosure it is so tight , informative,and holds subtile nuanses that I have never heard with other amps. very subtile. even 1952years records sounds absolutely tought. althought its performance very depends on other componnets.
#7 |
Would anyone care to elaborate any more on the "thermal compensation" methods that are both simple and effective?
I am finally getting around to assembling my Aleph-x's (just finished a long speaker building project), and I have read alot of ideas for taming the absolute offset during the warm-up period, but no one seems to have found or posted a simple solution (besides just deal with it)... I would imagine the commercial amplifiers settle down fairly quickly. In my case, my amplifier will probably see a lot of use during the warm-up / stabilization period, so shorter is better. Thanks, Jeff |
#8 |
The one and only
When you want to be very deliberate about thermal
compensation, you can always buy a range of thermistors from Digikey and put them in the appropriate spot. The thermistor decreases in resistance as the temperature rises, and you generally want to bracket it with fixed values of resistance in parallel and in series with it. The proportions of all three values are tailored to the need, and are usually easy, if tedious, to determine experimentally. Of course you want the thermistor in some thermal contact with the circuit. This 3 component network takes the place of an existing resistor in the circuit. If your XA amplifier drifts negative with temperature (which is what they usually do), you will want to put this network in place of the resistor between the Source and positive supply on the current source transistor which feeds the differential pair.
#9 | ||
Cutting 2 traces and cleaning a few spots to solder it on to. Just to be sure, do you mean R23 and R25 on attached schematic? The 2.2k (and 10k) resistors mentioned is R46 and R47, right? Just to avoid any confusion Quote:
Steen |
#10 |
Thanks Nelson!
I had tossed the idea around in my mind previously, this gives me more confidence. By the way, which component(s) should I thermally couple the thermistor to? The current source fet, the main heat sinks, diff pair, or just the ambient air inside the housing? My guess is the current source fet. (the more variables I can eliminate, the more likely I am to get it working more effectively...) Thanks, Jeff |
| best prices for fostex thats curent.thanx | roystr | Full Range | 2 | 20th January 2005 08:08 PM |
| input output diferential in LM317 | Pablo | Analogue Source | 4 | 15th June 2004 04:26 AM |
| double vs diferential | Praise! | Solid State | 11 | 7th November 2003 01:31 PM |
| Casscode Curent source | ppl | Solid State | 4 | 2nd May 2001 06:11 AM |
| Page generated in 0.11296 seconds (83.28% PHP - 16.72% MySQL) with 11 queries |
