Old 10th June 2006, 09:45 AM   #1
Buhl is offline Buhl  Denmark
Buhl's Avatar
Default About output pot. value and gain on BoZoS..
Hello Group
Having just finished a larger update on my X-BoSoZ, that included X-tra large heatsinks for the mosfets and a new 10Kohm alps blue aouput pot, I noticed that my gain have been reduced quite a bit from before when I used a 4,7Kohm - I.e. double the value - is this to bee expected ???
I use 124 ohm for the gain resistor, and this gives me about 20dB gain without the X-resistors, that have the value of 37Kohm - I am afraid to go lower as NP spoke of potential trouble with lower gain resistors, causing the need for matching of the FETS - but with the X-resistors reducing gain - should i just go lover - to 50 or 60 orh, or should use a higher value for the X-resistor. I judge the circuit to be about unity gain as it is now, and my Pearl MM pre and tuner would like at least 10 dB of gain...
Cheers !
Hans
"Calculations? We don't need no stinkin calculations! We just make them really big!" Quote: Nelson Pass
Old 10th June 2006, 10:23 AM   #2
Account Disabled
I think Nelson's comment must have meant that higher gain might create unpleasant level of distortion. If your X-feedback resistor is sized properly to find the “gain and acceptable distortion”, the size of gain resistor (of your 124) could go down even to zero. Isn’t the X-resistor to reduce the distortion . . . ?
Hope this info will help.
Old 10th June 2006, 07:44 PM   #3
Buhl's Avatar
Well, Sir Pass writes that the only cause that justifies matched devices is when the R15 resistor coupling the sources is close to zero, giving a gain of 50 (34dB) - this is proberly due to distortion as you write
Funny that he also writes that low value output pots will reduce the gain a bit - I got the opposite. I also changed the Xresistors from 39K to 37K when i changed the pot, because the only 39 ohm I had was metal wire wound, that I suspect is worse than my current carbon resistors.... I will tear it a part tomorrow, and try to put in higher value X-resistors, and mabye reduce R15...... fun, fun, fun....
Cheers !
Old 12th June 2006, 10:01 PM   #4
The one and only
Nelson Pass's Avatar
I think you're talking about two different resistors. The R15
which couples the Sources of the Mosfets will increase gain
as the value declines, but as it approaches 0 you will depend on
matching of the Mosfets to keep the DC current values of both
devices equal.
At the output resistance to ground, usually in the form of a pot,
is used to set the output gain also, and since that resistance
works as a shunt, a lower value pot will decrease the maximum
gain.
hi output MC=too little gain. pfcs49 Analogue Source 0 23rd February 2009 06:47 PM
Gain Matching Output device ???'s Zero Cool Everything Else 6 10th December 2006 04:56 PM
Output stage with gain rtarbell Solid State 18 27th October 2006 07:15 PM
BoZoS unbalanced again. lykkedk Pass Labs 5 21st December 2002 07:54 AM
Page generated in 0.08109 seconds (75.32% PHP - 24.68% MySQL) with 10 queries
