#21 |
diyAudio Moderator Emeritus
55-60° is a bit high and a small silent fans will work wonders.
Water cooling works fine too, some run them with alcohol cooled devices during the winter. ![]() /Hugo |
#22 |
bad luck, the supplier ran out of IRFP240s.. they are suggesting IRFP240PBF which is the lead free version.
will this be ok as an alternative? i've checked the net and their spec sheets are identical (the exact same file) Thanks! |
#23 |
Thay are the same. The tinning on the pins will be different but the internal die (the important part) will be exactly the same.
Graeme |
#24 | |
Hi Jh,I want to build the F1 power amp and I am in China.I tried to send a mail to you,but you do not wish to receive emails.Could you send a message to me.I will try to contact with you.Do you mind....? Regards, Leo |
#25 |
Account Disabled
| Building an AMP of a commecial piece but with top-notch parts | Oystein | Solid State | 3 | 9th July 2009 10:22 AM |
| Building some DIY interconnects little help sourcing parts? | Dougie085 | Everything Else | 17 | 18th March 2008 02:23 AM |
| Building a headphone amp from parts | Smokehouse Bob | Headphone Systems | 13 | 13th August 2007 03:26 PM |
| building a sonotube from the parts from a 12 inch partsexpress sub | michelevit | Subwoofers | 9 | 4th August 2006 04:14 AM |
| Building a table from Linn parts | sleepy | Analogue Source | 11 | 8th June 2003 08:02 PM |
