building firstwatt f1 - questions on parts
Old 11th June 2006, 07:52 AM   #11
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by awpagan
play's havoc with my maths sometimes
Adresses, phone and bank account numbers from 30 years ago.
Biggest problem are passwords, i remember everyone i ever used, but knowing which one is the latest is a bummer.
It's like toiletpaper in the supermarket, 50 different types and brands but not a clue which one to buy.
(i know a few who bring their 1 & only along when they go transcontinental. trans-incontinental ?)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 11th June 2006, 08:04 AM   #12
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Jacco,
Don't confuse members to use toiletpaper instead of mica or kapton. and vice versa...
/Hugo
Old 11th June 2006, 08:10 AM   #13
awpagan is offline awpagan  Australia
Is the "1 and only" the same as "the 1 that must be odey'd"
allan
Sorry guys for hijacking the thread
Indecision makes the world gone round.
Maybe
Old 11th June 2006, 09:26 AM   #14
Hugo,
i was just about to mention that i found toiletpaper with the lowest thermal resistance.
And it's dead cheap, a roll will last a lifetime. Userfriendly, cut and paste job.
(it seems environmentalist researchers have even been experimenting with some kind of ecological thermal grease)
Old 11th June 2006, 09:52 AM   #15
NP still favors mica.
Shaving mica insulators thinner is really easy with an oldfashioned raisorblade.(also named CocaCola blade)
Consider using Aluminium Oxide insulators.
Old 12th June 2006, 06:54 AM   #16
choariwap is offline choariwap  Philippines
thanks again for the responses!
i'm almost there in terms of BOM... one last thing (i hope) to ask:
i've been looking for a toroidal transfo over at rs and farnell, but the best one i could find is a clairtronic 300VA 18V one. Will this be enough? I read in other posts that recommended is around 400-500VA.
thanks!
Old 12th June 2006, 07:11 AM   #17
Netlist's Avatar
Since the amp draws a constant 200W, 400VA would be recommended.
Or, if you can afford it, buy two transformers and make separate supplies for each channel.
/Hugo
Old 13th June 2006, 02:12 PM   #18
hi guys,
me again
i've shopped around for heatsinks and the best one i can find is .3 C/W (measures ar 300x300x40).
ambient temps where i live would be around 25 - 30 C.
this would put operating temp at 55 - 60C. is this feasible for the F1 or would i need to augment the heatsink? (thinking of some fans for a bit of active cooling)
thanks!
Old 13th June 2006, 03:19 PM   #19
jh6you is offline jh6you
Account Disabled
Compromise bias current . . . :rdevil:
The highly efficient corns still welcome lower current !!!
Where is this :rdevil: ????????????
Am I still drunk ~~~ ???
Good luck!!!
Old 13th June 2006, 04:16 PM   #20
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Good luck!!!
yap-too much sljivovica
rdevil instead devilr
not same as yangyin instead yinyang
besides-you invented new breed of spk cabs-corn?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
building firstwatt f1 - questions on partsHide this!Advertise here!
Building an AMP of a commecial piece but with top-notch parts Oystein Solid State 3 9th July 2009 10:22 AM
Building some DIY interconnects little help sourcing parts? Dougie085 Everything Else 17 18th March 2008 02:23 AM
Building a headphone amp from parts Smokehouse Bob Headphone Systems 13 13th August 2007 03:26 PM
building a sonotube from the parts from a 12 inch partsexpress sub michelevit Subwoofers 9 4th August 2006 04:14 AM
Building a table from Linn parts sleepy Analogue Source 11 8th June 2003 08:02 PM
Copyright ©1999-2017 diyAudio
