Hello to all, hello Mr. Pass,
on Audiogon I found a used X 250.5 and a used X 350.5 Pass Labs power amplifier offered by a dealer. The devices were operated at 110 VAC 60 Hz. Today I run a Pass X 250, might want to upgrade to .5 but would need to operate them at 220/230 VAC 50 Hz. My complete system works at that voltage. I read in some earlier posts here (I think even one was from Mr. Pass) that you must only change some jumper settings and a fuse to operate them with different voltage, but I think to remember, that this answer was related to the earlier X250.0 model. Is this still valid fo the newer X.5 series ? Could someone please help me with this question ? Thanks in advance for your time. Regards N.S. |
#2 |
The one and only
In general you can re-tap the primaries, as they have
dual primary coils, however currently X600.5 and X1000.5 amplifiers have dedicated voltage transformers, and would require transformer replacement. At any given time it would be wise to check with the factory. |
#3 |
Alternatively I would appreciate any hints how you could
retrofit the improved HF/RF filtering of the newer .5 X-series to my "older" X250. - which parts ? - can I order them from Mr. Pass ? - how to install them properly ? I ask this, because my system sometimes sounds a little to harsh or letīs say VERY honest with bad recordings. Many thanks in advance for ANY hint related to reducing "honesty" to make a Pass X1/X250 combo a little more foregivable. Many thanks ain advance. Regards N.S. |
#4 |
Dear Nelson,
thanks for your superfast reply. Could I contact someone of the factory via email, who would provide me with the particular part of the circuit diagram, so I could safely re-tab the primaries of the transformer to the right 220/230 VAC coils ? Or is this unmistakable, because there is only one coil for each + and - left, to which I would have to re-tab the primaries ? Thanks again. Regards N.S. |
#5 |
The one and only
You can email me with the request.
| HIfonics BXi 1606 voltage float sound issue | Dealer | Car Audio | 12 | 3rd August 2009 01:13 PM |
| Dissimilar metal voltage source issue | bcdzt5 | Parts | 5 | 11th March 2008 12:58 AM |
| LM3875 Amplifier Voltage Issue | kblsnbts | Chip Amps | 8 | 6th March 2008 03:04 PM |
| help! power supply voltage issue | jlg4104 | Tubes / Valves | 15 | 2nd December 2002 06:35 PM |
| Page generated in 0.07283 seconds (75.77% PHP - 24.23% MySQL) with 10 queries |
