boz i use 10000uf (ELNA BLACK AUDIO GRADE) cause i had it in hand.
tone Member Joined 2002 2002-12-01 12:39 pm #21 2002-12-01 12:39 pm #21 boz i use 10000uf (ELNA BLACK AUDIO GRADE) cause i had it in hand. ••• More options Share jh6you Disabled Account Joined 2002 2002-12-01 3:25 pm #22 2002-12-01 3:25 pm #22 The end justifies the means. Be happy... JH ••• More options Share tone Member Joined 2002 2002-12-01 8:52 pm #23 2002-12-01 8:52 pm #23 boz..pls help hi all, the boz is working but clipping...how to check bias?? which resistor should i change to correct the bias? im getting 1 over volts only at the "source" pin b4 the 100ohm resistor..thanks in advance ••• More options Share H Henrik Member Joined 2002 2002-12-01 10:23 pm #24 2002-12-01 10:23 pm #24 If Your powersupply is 30v then change the following values: R101 => 18K R108 => 51 R104 => 510 ••• More options Share tone Member Joined 2002 2002-12-02 3:42 am #25 2002-12-02 3:42 am #25 boz..pls help im running at 50volts..ive fix the power supply..how do u calculate the value of resistor? ••• More options Share H Henrik Member Joined 2002 2002-12-02 7:58 am #26 2002-12-02 7:58 am #26 then all should be ok! Have ajusted the trimmer to get about 4V at the mosfet sourcepin? ••• More options Share Prev 1 2 First Prev 2 of 2 Go to page Go Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link
